Stein2088
Ok, so here it is. I got bored one day at work and found a 6.0 for sale with low miles. Ive been looking around on the site A LOT but I want to make sure I'm not missing anything in addition to finding out a little bit more about the trans. But first, this is my understanding. The swap will be straight forward. Pull the old girl out (if you can call 80K old) and put the new one in.. It's the same block all of my accessories will mount up. Basiclly I will reuse my entire exhaust system, and Intake manifold. The onlything changing is the block and heads. I need to get my computer reprogramed and thats it. Now for my trans question... Everyone that I have seen post recomends putting in servos changing to torq conv. to make the trans stronger. Wouldn't it be better to just use the trans that goes with the 6.0 or doesn't it work with my tahoe?
RECAP
5.3 -> 6.0 In 03 Tahoe Z71
Changes:
-Block and Heads
-Reprogram Comp-(Is this 100% necessary and can you buy a reprogramer to do it or do i have to take it somewhere?
Stays:
-Intake Manif
-Exhaust Manif
Questions:
-Trans- Would I be able to use the trans that came with the 6.0 or do I have to upgrade the stocker.
Finally, did I miss anything??? I live in Butler, PA and I will be moving to IL for the summer toeing a U-haul with a bike in it so I'm not looking to break down anytime soon... Also all thoughts comments and suggestions are greatly appreciated.
Thanks in advance!!!
P.S. 5.3 runs good so if anyone is interested.....
RECAP
Changes:
-Block and Heads
Stays:
-Intake Manif
-Exhaust Manif
Questions:
