njJohn
I had a vibration in my new to me '92 Blazer. Around town I never noticed it. I fixed a slight miss and engine stimble and was quite happy. Till I tried to drive to work on hte Parkway. Pretty bad vibration from 35ish to 55ish. Finally got it on my Buddies lift yesturday and found it to be the u-joints. They were replacements, but not quality ones and dry. So now I got 2 new TRW's and all is fine.
I was also on his lift to put the lowering shackles to even out my 1" crank down in the front. Well the bolts are seized in the bushings. Without wanting to take the whole spring down and get into a bigger project. I just cranked the front back up.
edit: the vibration would only be while on the gas at those speeds. Coasting it wouldn't do it.
