4 wheel drive
Ericbath
I have a 2012 Yukon SLT and when driving in 4 wheel I’m hearing a low winding noise. Was told the differentials are good meaning they have oil. Nothing noticeable in the handling of the vehicle. Any advice would be great
E
Ericbath
I’m thinking 4wheel hi, it doesn’t have a distinction between the two just has an ⬆️4
Big Mama
Virginia
Did you check the fluid levels along with the transfer case? Are you in 4 hi or low when this happens and what surface are you driving on? There can be several reasons for this and not all are bad.
E
Ericbath
Regular surface roads during snow. What fluid levels? I got an oil change done
GMCChevy
Are the roads clear? You've got more going on in 4wd which can cause added noise and using it when not needed can add stress to it and make noises more noticeable.
E
Ericbath
I only use 4 wheel when on the beach or have snow covered roads
Fless
Super Moderator
Elev 5,280
Transfer case fluid needs to be checked for level and quality of fluid. Is it full and what does the fluid look/smell like?
E
Ericbath
Last time it was checked they said it was good and full
Big Mama
Virginia
You said you were told the front and rear differential fluids were good. I was asking if you were certain. Not all oil change places are honest.
jjmasterson
