4 kicker cvr--what amp to push them have them wired at 2 ohm
texaschevyryder
LAWTON,OKLAHOMA
m trying to find out what amp i would need to push these 4 12's im thinking the kicker 1500.1 though i would ask u guys since yall are more experienced
drowndindreams
Unknown
theyre rated at 150 - 300 rms a piece. so a strong 4 channel amp, or a mono amp wired to the subs in parallel
yukonjon
Tacoma Washington
That amp would be fine to power those subs depending on how you wire them. If you wire the subs correctly you can either get an 8 ohm load or a 2 ohm load and with the 2 ohm that amp would be fine if not a little excessive. The zx1000.1 would be a little less money and still get good quality from the subs. Check out this diagram and you can see how to wire the subs together.
www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=4&woofer_imp=4
JamesinAbilene
