2023 Tahoe Liftgate Latch Replacement
pilldok90
Any videos out there or instructions on how to replace rear liftgate latch on 2023 Chevrolet Tahoe? Can't seem to find. Thanks!
This may be he3lpful to get you started.
From Dr. Google:
To replace a 2023 Chevy liftgate latch, you'll typically remove the inner panel by popping clips and unscrewing Torx screws (T27/T30), access the latch from behind, disconnect the wiring harness, unbolt the old latch (often 10mm bolts), and reverse the process with the new part, using a trim tool and sockets for the job, with videos showing specific steps for models like Tahoe or Bolt EUV.
This video provides a DIY guide to replacing the liftgate latch:
00:29
DIY Overdrive
YouTube • Jul 18, 2025
General Steps (May Vary by Model):
  1. Open the Liftgate: Use the key fob to open the glass or the whole liftgate if possible to get started.
  2. Access the Panel: Open the glass and remove a T27 Torx screw near the strap; then pry off clips to partially remove the inner panel, allowing access to the motor wiring and latch area.
  3. Remove the Panel: Work around the edges, using a pry tool to pop clips and potentially sliding the panel up/forward to fully remove it, revealing the latch.
  4. Disconnect Wiring: Unplug the electrical connector from the latch and potentially remove clips or grommets for the wiring harness.
  5. Remove the Latch: Use a 10mm socket to remove the bolts holding the latch in place and pull the old latch out.
  6. Install New Latch: Mount the new latch, reconnect the harness, and reverse the panel removal steps, ensuring all clips snap back in and screws are tight.
Or this....
Let us know if these are helpful to you.
