2021 Tahoe temperature actuator
Bobbybog
I get only heat coming from the drivers side vents. Passenger and rear work fine for cold AC. I purchased a GM temperature actuator and have it in hand. Can someone give me some guidance as to where I find it at so I can replace this thing? Do I have to remove dash to replace?
Thanks in advance!!!
F9thSkynet
Have you found it yet? The actuator? Witch side are you looking to do what code did you get in your BCM?
Durobans
