Thank you. I'm new to the forum having a little trouble navigating. The new trans is under warranty. Is the TC part of the transmission drive train? Thanks again.I’d consider initiating a shift motor relearn on the transfer case and differential components. The front diff electric worm motor may be slow or binding. When you go into Auto or 4hi the front electric motor fully engages and the transfer case electric shift motor engages appropriately (immediately when selecting 4hi or when needed in Auto). Please correct me if I’m wrong here.
The front worm drive motor is easy to test. Takes a minute to unplug the connector, unscrew the motor assembly from the front differential, and plug the connector back in. Have a friend engage the 4hi or Auto with the key on/engine off. The tip of the motor should move forward. Maybe video the motor when it does this and compare to a brand new one.
I leave my work’s 2012 Tahoe in auto all winter and there is slight binding on tight turns.
A Tech II / scantool commanded relearn might rule out and or detect issues with the transfer case electric motor.
