Hi
I have a 2004 Tahoe with approx 130000mils on it. During the last half year it has started to use oil. It uses the same amount of oil between oil changes as it uses on an oil change. I was kinda hoping the valve cover with the PCV valve in it would be the reason for that, so I bought the new improved cover. At the same time I bought new spark plugs so I could change those. When I was swapping them, I found one spark plug to be worn different. It had the tip burnt of and it was full off black residue. This spark plugs had 18000miles on them. Another thing I noticed when driving, was a noise from the engine. The noise is only there when the engine is under load. The sounded is like when you pinch a tin can rapidly.
I have added pictures of the spark plugs.
What could cause the spark plug to look like this?
What could be the reason for the tin can sound I hear?
HD
HD
