2004 tahoe center console swap HELP!!!!
dondave323
los Angeles ca
Hi am new her any help will really help
I have a 2004 tahoe that I want to install full center console to it right now it has the seat in the middle what exactly do I need to make this happen? And from what year do I need the center console.....thanks
Blue2002Tahoe
The console should be a match from 2000-06
Sent from my SPH-L720 using Tapatalk
BaMaDuDe87
Bama
Console from 03-06 and a glove box panel or you could cut you current glove box panel.
Sent from my Galaxy Nexus using Tapatalk
z0lt3c
Central NJ
I did this in a 2003 Suburban. Here is a pic of the parts you need in addition to the center console;
And here is what it looks like mostly installed;
D
dondave323
los Angeles ca
Do I have to change the plastic that goes under the streering wheel? Are all the consoles from 03-06 tahoe , suburban, silberado the same?
BaMaDuDe87
Bama
No. Basically the only thing that would vary is rear vents vs none and rear audio controls vs rear pocket.
BrokenTV GUy
