2003 Yukon problem with gauges
pshumar
PA
Hey guys,
Having an issue with my instrument cluster in the Yukon. Was working for awhile then one day when I started the truck nothing came on. Backlights work but none of the gauges (tach, spedo, fuel, temp etc) or evic start up. After driving for a little bit it would come on out of no where then work for awhile.
It has been several days and they have not come back on :(
Thought it may be a bad ground? Any help would be appreciated!!
Thanks
Pete
blueflamed03
Oklahoma
turn key to on position, pull gear selector to D, pull plastc dash part off. There are 4 I believe 8mm bolts holding cluster in. Remove, and pull cluster out. Make sure there are two large plugs, plugged securly into the cluster.
I can pull mine in about 3 minutes. First thing to check.
Welcome to the site!
P
pshumar
PA
Awesome! Thanks for the advice. I will check that out today.
P
pshumar
PA
So I took out the cluster and the harness was in securely. I messed around with the wires and it came back on briefly and then went out again. Started the car up and it worked again but after a little while the cluster shut off. Has not worked again today.
Any ideas?
P
pshumar
PA
Yeah that was what I was thinking. I am going to take it off again when I have some time this weekend and see what is going on.
P
pshumar
PA
The lights work for the back lighting and needles.
Its the cluster itself that doesn't come on. When I turn the car on something comes on like the gear selector, odometer, needles dont move etc...
Sometimes it comes on after 20mins or so of driving but hasnt in awhile...
