2000 Yukon, double din wiring? HELP
Mvfootball1
Shoreview, Minnesota
So I finally purchased my double din yesterday. I have made all of the necessary modifications to fit it nicely, So can anyone tell me how to wire this thing up?
I have a factory amp, is it best to use that? Step by step would be great, photos are good to!
I appreciate it.
Btw, the unit is a pioneer avic-d3 with navigation
vatahoelt
NoVa
X2 to what he said. Wiring adapter is all u'll need. Along with an antenna adapter and xm tuner if u have that.
M
Mvfootball1
Yeah I have the wiring harness and mounting kit I bought from best buy...I know there's a couple things with the wiring i have to do for it to play sound tho, does anyone know exactly what wires go to what?
groundscr8pr
flaccid member
scarborough maine
there will be a pink amp turn on wire in the secondary harness. hook the blue with white amp turn on lead from your deck to the pink.
vatahoelt
NoVa
it should be wire for wire. only wire from the pac harness i got that i didn't hook up, was the blue motorized antenna wire.
M
Mvfootball1
I wish I would have checked this post again before I did it all, could not figure out how to get the amp turn on. Anyways, its all hooked up and working (will post pics soon) But something must be wrong because it will not let me watch DVDs or use some of the navigation features even when the truck is in park with the e-brake on. It wont let me type in an address or anything. Any ideas?
groundscr8pr
flaccid member
scarborough maine
there should be a wire for the ebrake. on some pioneers ther is a gyro that senses when the veh is moving. on some decks u cant just ground the ebrake wire. on some you need a switch to reset the wire to ground.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
then you need to hook up the ebrake wire and put the ebrake on.
double check you are on the right side of the switch.
Jamison
Chevy Fan
Knoxville, TN
I have this unit in my Lexus IS300. Here ya go:
1. Remove the yellow and black mute wire from the harness using a toothpick.
2. Rotate and place the mute wire in the slot directly above where you removed it from.
3. Ground that wire and the solid green parking break wire to the stereo ground
That should take care of it....
Nickleahy23
Portage/Menomonie, WI
i had to cut an orange wire i believe to make the sound work for the rear...it was on the secondary harness in the dash..
i used a relay for my dvd feature..i wish i could remember how i did it lol
M
Mvfootball1
Okay did the bypass tonight and finalllly I am all done with this. I kind of procrastinated on this project so it took longer than expected.
So all said and done, I have $500 into everything, and it looks/work great. I didnt do the traditional fabrication for the 00-02 trucks....I got a double din bucket and bezel....n fabbed the HVAC controls, took no time and looks good.
M
Mvfootball1
So the bypass worked last night and now today....wont let me view dvds while driving, but then when i stop....the dvd re appears....any ideas?
Jamison
Chevy Fan
Knoxville, TN
Did you move and ground the yellow wire that I suggested? Also, did you ground the parking brake wire too?
SuburbanPassion95
