18 Tahoe LT Skid Plates
MLML
What needs to be modified on the LT to fit the Z71 skid plates? Is it worth it, or are there better after market options. I have the max trailering package on my LT, but want to add skid plates and modify air dam/valance for more front clearance. Suggestions?
AZCreeker
Hello MLML,
I did the following to improve the front departure angle /ground clearance:
I removed the stock air dam, also called valance also called deflector and installed the police version, PPV Tahoe model.
here is a post a made about it who ended up being a "sticky" on the forum
you could also carefully cut your stock piece but I like the clean look of this one better myself.
https://www.tahoeyukonforum.com/thr...hat-comes-on-police-model.90043/#post-1074793
I also installed in all four corners Bilstein 5100 Shocks, the front one raise up the truck up adjustable from 0 to 1.75". I set those to max, and the truck is perfectly levelled now. well the rear is still 1/4" or 1/2" a bit higher but its ok first because I have a suburban that needs it with how the rear hang out and fown visually and also because we haul tons of stuff.
also got an alignment.
I went off road last week and got some really good articulation in the desert, clearance was amazing compared to stock height and stock valance.
https://redirect.viglink.com/?format=go&jsonp=vglnk_154963333366815&key=3deb13e6de5efc47d7afda436f2a8ff0&libId=jrw3o4vu01000b5q000DAp4pl0wke&loc=https://www.tahoeyukonforum.com/threads/bilstein-5100-vs-level-spacers-for-2018-tahoe.100057/#post-1279301&v=1&opt=true&out=https://www.suspensionconnection.com/f4-be5-e376-h0-tahoe-bilstein.html&ref=https://www.tahoeyukonforum.com/search/22556243/&title=Bilstein 5100 vs level spacers for 2018 Tahoe | Chevy Tahoe Forum | GMC Yukon Forum | Tahoe Z71 | Cadillac Escalade - Tahoe Yukon Forum&txt=https://www.suspensionconnection.com/f4-be5-e376-h0-tahoe-bilstein.html
lastly, for the skid plate I would simply install the chevrolet accessory skid plate:
https://accessories.chevrolet.com/p...t-under-body-shield-23176881?categoryId=12002
M
MLML
That's an awesome write up and great looking Suburban! I found a fabrication guy who can make some beefy skid plates for not much more than the OEM ones. We'll see. Pics soon.
brice715
