1 Fi BTL or 2 Fi SSD's?
  • BTL
    Votes: 3 30.0%
  • SSD's
    Votes: 7 70.0%
  • Total voters
jvoisel
New Orleans, La
Trying to decide rite now on ordering one Fi BTL 18 or 2 FI SSD 18's(all options on subs which ever way I go.) Either way they will be powered off of a saz 1500d and the box will be built to specs. Mainly looking for spl but won't be trying to compete or anything.
Specs on the subs,
BTL18
DUAL 1 | DUAL 2
Fs: 31.9 Hz | 31.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 6.26 | 6.42
Qes: .26 | .24
Qts: .24 | .023
Mms: 313g | 329g
Sd: 1210cm^2 | 1210cm^2
Vas: 163.1 l | 163.1 l
Spl: 94.9dB 1W/1m | 94.9dB 1W/1m
Bl: 18.3 N/A | 27.2 N/A
Xmax: 28mm * | 28mm *
Rms: 2000W * | 2000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 5-10cuft | 5-10cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth: 10.250” | 10.250”
Displacement: 0.26cuft | 0.26cuft
SSD18
DUAL 1 | DUAL 2
Fs: 27.6 Hz | 27.6 Hz
Qms: 9.56 | 9.56
Qes: .47 | .47
Qts: .45 | .45
Mms:338g | 338g
Cms: 0.098mm/N | 0.098mm/N
Vas: 201.4 l | 201.4 l
Spl: 91.4dB 1W/1m | 91.4dB 1W/1m
Bl: 13.1 N/A | 18.7 N/A
Xmax: 21mm
Rms: 800W
Sealed box: 3.5-5 cuft
Ported box: 6-10 cuft @ 33Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 9.500”
Displacement: 0.22cuft
Opinions?
Tahoeatl
Duluth,Ga
Same power... 2 18's vs 1...1 super sub vs 2 good subs.. the 2 good subs should win due to the box they're gonna be in and double the cone area...SHOULD...
doesnt always work out that way.
but if you have 1500rms imo either setup will sound great but 2 ssd's SHOULD be louder due to double the cone area alone. 1500rms is just warming a BTL18 up... if your talking 2500-3000rms then the btl wakes up and hurts you
briannorris
