Auto dimming
LewL
I have used the search function but cannot seem to find anything. Does the 2025-26 Yukon AT4/Denali Ultimate have auto dimming headlights? If so, how do you turn on that function?
Thanks!
Javelina
Pleasanton, CA
Search the Owner's Manual for "High-Beam Systems". First of several paragraphs:
High-Beam Systems
IntelliBeam System
If equipped, this system turns the high-beam
headlamps on and off according to surrounding
traffic conditions.
The system turns the high-beam headlamps on
when it is dark enough and there is no other
traffic present.
GMCChevy
A Denali shold have it, most of the higher trim models either Tahoe or Yukon it's a standard feature.
Check the owners manual for how it works. It should be on by default and only disable when you manually control the high beams or turn on the fog lights.
L
LewL
Thanks. One more dumb question - did Owners Manuals come with the 2025 Yukon AT4s? I did not get one with mine.
E_S_D
You can access the owner's manual via the MyChevrolet app on your phone or by using the infotainment center in your vehicle.
ZKWBQD
Thanks!
For auto dimming to work, the light selector must be in "Auto", I never use that. I always control my lights manually because I don't want my daytime running lights to be on during the day. When you put the headlight switch too "on" you have full manual control of the high-beams.
rlhmarines
Senior Member
Marine Corps Supporting Member
If you press your fog lights button to on it will also cancel out the auto high beam operations but it will go back to working in auto when the fog lights are turned off again. Once you set the auto high beam it will stay in auto mode but it will cancel if you manually flash your headlights and you’ll have to reset it again.
CWool
