Water when raining
liljdub614
For some time now I’ve been dealing with having water getting in and dripping down kick panel on passenger side. The highest I’ve been able to trace it was behind the panel on the side of the dash.
And now I’ve got water getting in some how in my trunk? Any ideas on what it could be I’ve tested the sunroof drain and they seem fine
GMT800 2005 Tahoe Z71
Navy Supporting Member
I recently had a 2005 Tahoe, owned by a friend of mine, that had water coming in under dash on the d/s. Turned out it was a floor pan seam. Resealed and stayed dry. PITA to locate and deal with but that was the source.
Your rear leak could be from a wheel well seam?
Foggy
KS
Clean out the sunroof drains. Very common..
Or sometimes the drains tubes separate from each other
where there is a "fitting" like a T or a 90*
You'll have to remove enough stuff to inspect them thoroughly
LsHart
Senior Member
Third brake light and the windshield possibly? What r u working on?
The Whip
