Chevrolet Suburban 3500 Questions
Slatinaa
TripleFJeff, I can do that if it will tell me color of wire and what it goes to. Have you used the service? What is the link?
Seats are interchangeable the generation year tahoe, suburban, escalade and gmc.
Read a write up where guy installed escalade seats.
My Suburban came with clean cloth seats that I don’t mind. Will wear them out and if need to be change out, but for now I really like them. They are verily available since all the suvs above use them.
B
Bigburb3500
I do not think Escalade seats are direct replacements. They will bolt in but because some functionality is controlled thru the infotainment system it will likely be difficult/not possible to operate.
Yukon Denali seats should be plug and play.
Geotrash
Dave
Richmond, VA
Got the Denali cluster installed today.
Before:
After:
Mileage came over correctly. However I haven’t been able to get Apple Maps to work on the navigation screen via either wired (direct) or wireless CarPlay (with adapter). Album art comes over but the playlist names don’t. Seems to get more data the longer it’s connected and running so we’ll see if anything changes on our next trip.
I did not install the HUD gear yet.
One thing I love: tow/haul mode displays the transmission temperature in place of voltage.
Going to hang on to the original cluster for a few weeks at least to make sure I like this new one.
Geotrash
Dave
Richmond, VA
Getting a service steering system message after every startup now, but neither my topdon or autel Bluetooth scanners are finding any trouble codes related to it. My guess is that both of them are seeing this as a normal 1500 suburban and can’t scan the modules unique to the 3500 appropriately. Might need to invest in a mvi tool.
Slatinaa
Team, quick update on my center console harness.
Finally found a little time to go through wires on my 16 Suburban 3500 LS that were cut and compare to the wire harness I purchased from a wrecking yard.
I have attached photo of the wire harness that Im trying to attach to my cut harness.
I have also attached written colors that are on my suburban and compared to the harness I bought from wrecking yard to attach to my suburban.
My next step is to somehow find out what each of these colors are for before connecting.
What route should I go to find color codes. I’ve been unsuccessful finding anything online.
Would my local Chevy dealer have this info?
Thank you,
TripleFJeff
Thank you,
All of that information is in the upfitter manual that I linked to above. Did you look at it? For example, X300 is that big connector. Here is an example.
TripleFJeff
Off on a tangent... curious from those of you who have gone from a 08-13 2500 (6 Speed) to a 3500, is your towing mileage any different? The 3500 has 4.10s vs 3.73s on the 2500, but with the 2500 towing close to 10K it doesn't spend much time in 6th except going down hills.
Geotrash
Dave
Richmond, VA
Well, it’s not a direct comparison to what you’re asking, but I used to pull the same camper with a 2012 Yukon XL with a 6.2 L. With that, I’d get about 7.5 on average towing, and with the suburban 3500 I’m getting about 8.3.
WorldsWorstTruck
