Walkerfever
Missouri
We are replacing a section of fence in our back yard, and Home Depot had a pretty good deal ($1.48 each vs $2.18 each, then another $50 off if I spent $300). They fit...however next time I'm leaving my daughter at home so I have the entire back of the Yukon...
Loki223
Elk, WA
New passenger side CV axle went on this weekend. Nice easy 15 minute job, didn't even take the wheel off. Old one had torn boots, otherwise fine. Buddy of mine helped and i donated the old CV axle to him to rebuild and resell for his time since it sounds like he already has a buyer lined up for it.
Also confirmed, there is a leak in the freon system. Filled it up last year and it worked through whenever i filled it up through the end of usage of AC. Finally warm enough that the AC had wanted to pop on, and no AC. so that's fun. So i'll be investigating the AC system next before i buy new rubber to go with the rims i have sitting in the garage
jared999
Picked up a 2020 Tahoe a few months back. Just swapped out the cloth seats for lux leather a couple days ago. Now I have to figure out how to wire it and get power to the center console (It's a PPV). The seats have the modules for heat and cooled seats (or ventilated) and the console has the switches. I'll do some searches and hopefully someone else has already figured this out.
Congtoid
Swapped the water pump and belt tensioner last night, but ran into an issue.
Snapped 2 bolts on the pump, anybody have any recommendations on to how to remove them?
It's a 10mm bolt from the water pump pulley, I'd say about 1/2 inch in width?
gtrslngrchris
Man, that sucks. If it makes you feel better I overtorqued the first of my intake manifold bolts and ended up with this Monday night.
Was able to sit a nut right above it and weld the two together but I'm not sure how much that helps you. Lucky for me the threads were clean and I just didn't pay attention to the torque wrench setting on hour 9 of the day working on my car. If the threads had been bad and were the reason it snapped then I likely would have had a much worse time.
RLyukon19
