GranPrix
- Joined
- Sep 10, 2017
- Posts
- 723
- Reaction score
- 487
So I've been having crappy slow starts and sluggish acceleration and got a P0013 code. Did some searching on here and not much came up so I figured I'd post it up for anyone else getting a P0013.
I had the typical symptoms such as the engine light, difficulty starting and sluggish performance. I checked for vacuum leaks especially since I have a catch can and I had recently cleaned out the throttle body. New throttle body gasket was put in and everything else checked out fine so I moved on to the cam position sensor. Kinda a PIA to get to but not that hard.
Swapped it out, disconnected the battery, cleared the code, drove it for a couple miles and not longer have any issues. Sensor sits under the TB and the right.
