Front bumper removal instructions??
66 Galaxie
Going to add tow hooks to my high country and need to relocate ACC
d_hawk
Unless GM has developed a recovery hook specific for the LS/LT/High Country bumper cover then you are going to find the recovery hook for the 1500 series truck and Z71 trim package tahoe/suburban doesn’t stick out of the facia far enough to be used without damaging the bumper cover.
I found this out the hard way. The drivers side of my high country has a little removable panel, that’s even named something like recovery point cover and a recovery hook from a Z71 series suburban bolts up correctly, it’s just not long enough. To work properly the recovery hook needs to be 4 inches or so longer than what is used on the Z71 suburban/tahoe and the 1500 series trucks.
Sparksalot
Bastrop County, Texas
Stick out you say??? Who needs that. Thank God for soft shackles.
66 Galaxie
Great info, thanks!
Do you recall how long the tow hooks are??
66 Galaxie
If I can’t find longer tow hooks I’ll look into having something fabricated. I’ll let you know if I have any luck.
adamnalicea143e
