4x4 klunking/loose
ryangt
double team supreme
Jacksonville, Florida
I cannot figure anything out that is wrong in the front end, ive jacked it up, greased everything, put a wrench on everything and still, every time i go over a bump i can hear a clunk in the drivers side front suspension. Something sounds loose, but ive checked everything, wheelbearing check as well. Anyone have any ideas?
Modded
That Guy
Intermediate steering shaft could be the issuue, very commeon problem on your model year.....
ryangt
ryangt
double team supreme
what does that mean? Are you talking about the multi peice steering link between the steering wheel and pitman arm box? Im just not sure im trackin which one you mean. ALso is there a way to check?
---------- Post added at 03:14 PM ---------- Previous post was at 03:13 PM ----------
Ball joints?
i put the front end up in the air and looked around, tried to shake the wheels and so forth and got nothing. How can you tell if this is an issue?
ryangt
ryangt
double team supreme
ok so i unbolted the thing and sprayed in some wd40 and shook it around a bit, seems to fix the klunking but not for long. Does anyone have a part number for this thing so i can order a new one?
moto
