Pics of Suburbans/XLs with 2" lift?
Martinjmpr
Littleton, Co
Sorry, tried a search but couldn't find what I was looking for. Still shopping but wanted to see if anyone had pictures of a 'Burb or XL with a 2" key lift/leveling kit running either 32" or 33" tires? Trying to get an idea of which way to go.
I see lots of lifted non-XL Yukons and Tahoes but not a lot of lifted Suburbans or XLs.
Thanks in advance!
drew4216
Just installed tonight, i have 34" tires though, definitely recommend new socks in stead of shock adapters, the kit was 108 on e bay really happy with the way it drives, my 34s rub on turns if you don't want to trim go with a 275 70 18, i had a hard time researching also, but i have room for a 35 if i didn't mind some rubbing
Mondo
I have general grabbers 285/75 and I'm riding stock with no rubbing. And stock rims no spacers. You could have gone bigger. I just got the rough country kit and am about to have it installed. I will post before and after pics of the install on my Yukon XL.
Countryboy07
Here is a pic of my '05 Yukon. Currently waiting on Z71 rear springs and 1" spacers for the rear, so front is only leveled with the stock rear height. Running 275/60/20's.
Martinjmpr
Martinjmpr
Littleton, Co
Looks good! By my calculation your tires are 33", yes? Are you planning to go any bigger once you get your other components?
Is yours a 4x4? I can't tell from the pics.
Countryboy07
Correct. The 275/60 is like a 33x11. I may go 33x12.50, but that will only be if I get different wheels or have these refinished as these are getting pretty rough from the salt. Until that time, I will just roll on these or go back to my 16" stockers for a little while. Also, yes ours is 4x4.
Mondo
ok guys finally got my rough country 2inch leveling lift kit installed. Was not a hard install at all. I got 2 inches in the front but didnt get but 1/4 of an inch on the rear. To make the ride level the torsion keys are pretty much all the way backed out. So as of right now all 4 corners are sitting at 37.5 inches tall.
What can I do to lift the rear about 2 inches cause if I put the keys up about half way I'll get another 1.5-2 inches in the front.
The spacers the rough country kit came with were less than half an inch. should I get 2inch spring spacers ?
what is the difference between the springs on my truck ( 2002 Yukon XL SLT 1500 4x4 ) vs Z71 Springs??
I like the way it sits leveled but I really wanted to gain the 2 or more inches all the way around not just in the front.
Before the leveling kit
Rear Rough Country Shock N2.0
Rough Country torsion key vs Factory
After Rough Coutry Leveling kit
Durobans
