Speed-Engineering Catch Can
jough
jough
Arkansas
LS engines have a habit of sucking oil into the intake thru the PCV valve. This catch can separates the air and oil. It keeps the insides of intake cleaner.
bottomline2000
Dallas, TX
what other mounting options do we have for this? My truck's EGR system is mounted where they have their catch can.. I need this, but need options to mount it.
bottomline2000
Dallas, TX
:driver:Do a quick search here on this site and you will find numerous CC threads with all the info you want.
interested in the one in this thread.. haven't seen anyone else use this type. I like the sight view on it. nothing turns up on a search but this thre
nothing on the can in this thread.. THIS is the one I'm interested in since it has the sight window the side. everything else is a one bolt affair. maybe drill/tap the accesory bracket and mount there..oh well..i'll figure it out..
jough
jough
Arkansas
Got the Speed Engineering Catch Can installed and plumbed. You'll need to buy about 6' of 3/8" vacuum hose, two Tees and one or two elbows. I used anti-seize on the bolts going into the head and blue Loc-tite on the bolts going into the catch can.
Nothing registering on the sight tube yet.
I just did the Seafoam aerosol thru the throttle body treatment (VERY LITTLE smoke) and I'll change the oil soon.
OHSIXX
Milwaukee
Can you post a pic of your install? Thinking of doing this.......
jough
jough
Arkansas
See the link in the original post for pics on Speed Engineering website. The hose plumbing is very simple. Both valve cover vents go to one side of the catch can. I used the IN side closest to the engine. The passenger side vent tube is above the valve cover and pointing toward the front and the driver side is at the rear of the valve cover pointing up.
The OUT side of the catch can goes to two connections on the intake manifold. The passenger side connection is just behind the throttle body and the driver side is top center of the intake.
The passenger side connections are very short. I routed the driver side hoses in the space under the throttle body and above the water pump.
All the above is for a 2005 LQ9 using a 2004 5.3 flex fuel intake manifold. Others may slightly differ.
The catch can does not have IN and OUT marked, so you can do whatever you like. I got the hose & 3/8" fittings at O'Reilly's.
The clear sight tube is included with the kit. There are no instructions included.
ezdaar
Chat Troll
Redneck central, Aka Houston
If there is no Specific in/out ports on a Catch can, I'm sorry to say this but its a pos.
If they are built correct and actually function "good", they have a specific in and out port.
You would be shocked as to how much better a properly built can functions over a bad one.
Dont think for one second that a 140$ can works any better than a 50$ ebay can.
As 75% of the cans being sold are just hollow empty cans.
Manufactures that make quality functional cans show you whats inside them.
Properly built can, even tho this is a bottom of the barrel design. It still has a specific in and out, With a long passage way that helps cool and separate the air charge, then the abrupt 90* direction change to help force the oil from the air. then it includes a mesh baffle that increases the surface area by a million times that oil can cling to, thus separating even more oil from the air charge. This mesh is also being held up from the bottom of the can.
with a ported divider.
The more surface area the dirty air charge must pass by, the better it works.
High end cans have machined dividers that Slow and cool while making many direction changes to the dirty air charge as it passes through the can. it will be very difficult to see these designs posted on the web.
Pos non port specific can.
Omit the "inlet/outlet from this image, when looking at it"
This can merely allows gasses to pass through with NO functional baffle system.
It does not cool or separate the dirty air charge and the mesh that's inside it "IF" it even has any is basically worthless as the dirty air charge barely even passes through it, if it does at all.
Given the nature of the mesh, weight of oil, road conditions. that mesh will condense with oil, compact itself into the bottom of the can, thus becoming nothing more then a oily weight.
What little oil does get trapped is from sheer mass of the oil being flung out of the air charge as the air charge makes a abrupt direction change.
Both of those cans picture above have one major flaw..
The stainless or copper mesh.
It clogs up and must be cleaned and occasionally replaced.. its a very diry job.
This is also why the high end cans with CNC'd baffles cost so much more. they are simple to clean and never require replacement parts, along with many other design secrets.
This is the design I use when I build a can.
Its cheap and easy to build. I use stainless steel wire screens as my filter media.
I also angle the bottom of the inlet tube like a hypodermic needle. this gives the oil a nice pointy tip to collect on.
pic here for screen,
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash4/1402933_735360303158029_161726413_o.jpg
ezdaar
Chat Troll
Alot of these cans I see posted here at TYF with removable lowers, can be easily modified into a very functional can.
A copper tube, some stainless screen. and some time. is all it would take.
bottomline2000
Dallas, TX
I agree with EZ..The flow should be directional or the can is pointless. Does it have any filter media inside?
Conedaddy
