Constant air flow from HVAC system - even when OFF
bkboatnsleds
McHenry, IL
Details..
2003 Tahoe Ls Manual Dual control HVAC system..
No mater what I do I can not stop the airflow from the vents. I put it on dash or floor, and push the Recirc button .. still strong flow.
At highway speeds its almost the same amount as if I had the blower speed on 1.
Only think I can think is I have a door thats not closing.. Thoughts?
yukonjacks
A Vegitative State
The Confluence
Last week, I wanted just fresh air and I had hot air coming out, so I put the A/C on and I still had really hot air coming out the vents, I tried the floor, defrost, combos and straight on, still all hot air. Parked the truck and went hunting, started the truck up and the air was coming out cold again WTF
BlizzardX23
Sacramento, California
I've noticed while I have the air turned off, its still blowing down below through the footwell vets...and yea, it shouldnt be that strong...I have always wondered what that was about :shrug:
JKmotorsports
Austin, TX
The low air pressure area at the base of the windshield while driving forces air through the hvac intake. The faster the vehicle is moving, the lower the air pressure in the cowl area, therefore causing the higher air pressure to force more air into the lower pressure area. Aerodynamics. This is the same concept behind cowl induction.
If you have the system in recirc mode, the flow from outside of the vehicle should be blocked off. If you're still getting flow, it's possible you have a duct flap stuck open, inoperable actuator, bad module, or blower motor that isn't turning completely off.
Cobra
Austin, Tx. area
I like it keeps me from using th ac all the time esp. on the highway. I just change temp to hot or cold depending to where I want it and I get it without using system. The only way I can get it to stop is like JK said using recirculation mode.
bkboatnsleds
bkboatnsleds
McHenry, IL
Exactly!! But when I push my Recirc button it does not stop. I know the blower is turning off - I have a stuck vent or a bad actuator motor. Anyone know where it is?
JKmotorsports
Austin, TX
You can try letting the actuators re-calibrate and see if that helps.
Remove the HVAC/ECAS fuse for at least 10 seconds then re-install.
Start the vehicle and wait at least 40 seconds. The HVAC modules should recailbrate and sync.
If this doesn't help, it may be a mechanical problem like a sticking flap or just a bad actuator.
bkboatnsleds
bkboatnsleds
McHenry, IL
I tried the re-cal trick .. no luck. Any idea where the flap or actuator is located??
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
mine does the same thing, it seems like when it gets hot sometimes during winter days the a/c doesnt work
bkboatnsleds
bkboatnsleds
McHenry, IL
Figured it out!
the door behind the glove box is not opening / closing when it should. I used s spring hook top pull it closed and it worked for a few times but then it quit again.. Perhaps is the motor is going bad thaty moves this door.. ANyone ever replace this actuator? Whe its closed as it should... NO air comes in :) so nice,.... but its not ALWAYS working according to the switch - so its either sticking - or the motor is weak...
bkboatnsleds
bkboatnsleds
McHenry, IL
Im not convinced the actuator is bad - when i get it moving it, I can test it 100+ times and it continues to work - but then I walk away and come back to the truck and its stuck again.
Anyone have this experience?
Rivieraracing
Is it a spot that you could spray a little wd-40 on the moving parts? Not sure where you are talking about, just an idea!
bkboatnsleds
bkboatnsleds
McHenry, IL
I thought about this too.. But its kinda a crap shoot as you cant really see any of the moving mechanisms short of the actual door.
Rivieraracing
Even with a little mirror and a light? Like I said, I haven't looked in there before so I don't know what you are really seeing!
johnsonwillie199
