New 24's
ammar456
Just put them on! Wrapped up in 305/35's. Handles like crap now but that was expected (Big jump from 17's - 24's).
Getting a little bit of rubbing at the front and back of when I turn all the way, which sucks, but I assume it will take care of itself after doing that a few times by pushing the rubber out of the way (unless you guys with 24's have better suggestions).
Need a 2/3" drop next.
Before:
And with the 24's:
these are just quick iphone shots, will get some proper ones soon
KMeloney
What'd you do, swap the tires at a stop light?? LOL
NIGHT AND DAY difference. Looks so much better now. You must be psyched. Congrats on a great looking truck.
/< / /2 /<
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
Looks great man! :cheers: What kind of tail lights are those? Can you post a closeup pic of them from the side and from directly behind the truck?
Where are you located? Bahrain is it ?
A
ammar456
haha no that first pic was infront of the shop that put the tires on.
iwaslowr; ill get some proper pix of the car including the tail lights pretty later tonight or tomorrow
Modded
That Guy
Yeah man the truck looks real good, you can always change your shocks to make it ride better.
Since you plan on lowering next you are good to go, I have a 3" rear lowering kit you could buy.
Like stated above, where are you located?
Nickleahy23
Portage/Menomonie, WI
looks good..you said it handles worse? shit its no comparison from my stocks to my 24s...much better handling with the wider and stiffer tires imo..the ride is a bit worse, but response is much better
A
ammar456
well yeah the ride is worse but it also seems to follow any grooves in the road, and we have a bunch of them near where i live which sucks.
from Bahrain, that's pretty far away from you guys (ie, middle east), its a tiny island a few hundred miles away from dubai.
lowering is coming soon, im just trying to decide between regular 2/3 drop or airbags
what do you guys do about the rubbing? its not much, only on sharp turns
Modded
That Guy
Yeah I have rubbing too man on the stock wheels, ecpect I have a 2/5 drop and not a 2/3.
I say you only lower it 2/3, next case scenario is a 3/5. Because airbags requires alot of BS nobody wants to go through lol!
A
ammar456
mind elaborating on the BS? because I wanna make a decision soon and im still stuck in between the bags and regular 2/3"
as for the rubbing, its when turning the wheel to the extreme left or right. do you guys just let it be and fix itself, or is there anything u do?
Front
And back..
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
I'd like to get a kit like this from Universal Air Suspension... https://www.universalairsuspension.com/store/product_info.php?products_id=227
My tires are a little bigger than yours but I've had to do some heating/cutting on the plastic wheelwell liner, and once the lowering kit was installed a rubber mallet was used to slightly bend back the inner most tip of the front fender behind the front tires to prevent rubbing.
A
ammar456
cheers, might do that.
i got a quote from airbagit.com, comes out to a little under 2k, and with a few optional extras just over $2,300:
We do have a set-up for this Tahoe and it will allow you to lower it 2-3 below stock and back to stock or alittle above it. We have not tested this kit in harsh conditions but it has been sold around the world.
FRONT AIR STRUTS(INCLUDES AIRBAGS)
REAR AIR KIT(INCLUDES AIRBAGS AND MOUNTING BRACKETS)
3 GALLON HIGH-PRESSURE AIRTANK(OPTIONAL 5GALLON AIRTANK)
COMPRESSOR PSI CUT-OFF SWITCH
1/2HP COMPRESSOR 100% DUTY CYCLE 180PSI MAX(SEALED COMPRESSOR)4 WAY ELECTRIC AIR-VALVE SETUP 3/8" 160PS(INDEPENDENT CORNER CONTROL)
3/8 HI-PRESSURE AIRHOSE & FITTING KIT
4 FAST RESPONSE SWITCH-PANEL(OPTIONAL 10-SWITCH CONTROL UPGRADE UPON REQUEST)
(2) LIGHTED PSI GAUGES(OPTIONAL DIGITAL GAUGE UPGRADE UPON REQUEST)
*2-3 SECOND INFLATION/DEFLATION TIME
*4-CORNER CONTROL(FRONT-BACK, SIDE-SIDE, 4-CORNER INDIVIDUAL, AND PANCAKE)
Cost:1880.00
OPTIONAL UPGRADES:
-5 GALLON TANK>>25.00
-FILTRATION SYSTEM>>25.00
-SPEED CONTROL>>>24.00
-DIGITAL CONTROLLER WITH 8 PRESET HEIGHTS>>350.00
they estimated shipping to be around $100 depending on location for US addresses
turboeclips
Austin, TX
looks good man!
Rims make a night and day difference for appearance. Ride it out for a few days and see if the natural rubbing wears out the parts it rubs, so it won't rub anymore. Thats what I did. If that doesn't take care of it or you prefer not to wait, you can get a heat gun like iwaslowr said and slightly melt/mold the plastic away were it rubs.
Modded
That Guy
Yeah airbags are just too much.
When some one has 24s, the airbags can't even get you that low. Look at the pics of the Avalanche, the rear height its at can be achieved with a rear 5" coil drop w/o isolators, and as for the front, a 4" drop on a Tahoe with 24/26s is going to have the fender like .5" above the tire.
So airbags can only get one rellly low when they are parked and not driving, can drive the car that low anyways because the front camber is way out of line when aired out big wheels w/o control arm modifications.
Now if your have 22s or smealler, irbags can take you a longer way w/o all the extra BS.
Then ontop of all this, one has to worry about keeping/maintaining the system, WAY too much work lol.
A
ammar456
Bahrain... That's a land far far away. Lol... It's in the Middle East...
More pix:
iwasslowr here's the close up of the lights:
Strip5150
How did the rubbing end up? did you just ride it out or did you take a heat gun to the plastic?
johnsonwillie199
