No rear heat???
chevync
North Carolina
28f this morning so I fired up the hoe let her warm up, front heat works great, I went to turn on the rear heat, all I got was blowing cold air, any idea whats up?
chevync
chevync
North Carolina
Jesus, add antifreeze! lol I am losing antifreeze from somewhere, the motor only has 1500 miles on it, I thought my low coolant sensor was bad, it never overheated, I added a gallon of antifreeze and it's still a little low. I checked all fluids and nothing it leaking.
JesusArTorres
Tulsa, OK
That fixed the rear heat? I recently filled the coolant.
DansOtter
North Carolina
I haven't fixed it yet... still researching the crap out of it. I'm still a little vague on the part number to order. My part number is: 21997590. However it looks like I might be able to replace it with AC Delco prt # 15-73506. Here it is on Amazon:
http://www.amazon.com/ACDelco-15-73...automotive&vehicleId=2&vehicleType=automotive
According to Amazon, it fits an '05 Tahoe (which is what I have btw). $59 bucks is hard to beat, and their return policy is pretty good. I'll probably give it a whirl. I'll let you know if it works.
Dan
GMT800 2005 Tahoe Z71
Navy Supporting Member
You guys that were low on coolant, did you pressure test the system and look for leak. If system is full then can be the actuator but I have heard of taking them apart and cleaning and then working again.
DansOtter
North Carolina
Thanks, I'll check this out. Is this how you fixed it?
So good news... that fixed it! If you've already determined that it's not coolant-related (which, I'd venture a guess that you don't... because you'd have engine overheating issues and no interior heat at all), then this is probably what you need:
http://www.amazon.com/gp/product/B000S2SHZK/ref=oh_aui_detailpage_o03_s01?ie=UTF8&psc=1
Watch the YouTube links in my earlier posts to see how to replace it.
Good Luck.
Dan
Red Rider
Wow, that puppy went up!! I paid 58 for mine from Amazon.
Red Rider
Though I really found some different part numbers out there. This was was listed at first with the old part number, though they send you the updated part.
DansOtter
North Carolina
Yeah that's what I ran into too. The original part in mine was 21997590 (mine is an '05 Tahoe LT Auturide). The AC Delco replacement part # that was printed on the sticker was 15832319 (ordered from that amazon link above).
Not sure what the difference is. But it's working for me now, and the wife's happy. So I'm happy.
6point2lovelifers
