trailer hitch
dans99
Cape Cod
I was at the junkyard and seen a frame mounted receiver from a 97 suburban. Would it fit a my 99 tahoe??
D
dans99
Cape Cod
I wont be towing anything big I just have a 12ft. boat for duck hunting but I like having the option of towing something bigger if need be.
99YukonJS
After a quick search, yes it will fit.
Mine is bolted on. It's a class 3 rated at 5,000lbs. You could reuse the old fasteners or buy new ones, but just go with high grade bolts. :)
D
dans99
Cape Cod
Thanks guys, I am going to get some good grade bolts and bolt it up. not a bad find at the yard for $20
1weasel
Laramie, WY
If I can tow a 21' open bow without welding one on, you can tow a 12' hunting boat.
D
dans99
Cape Cod
Ok....next question;) what size bolts do I need to use to mount it up?...Thanks again guys.
99YukonJS
Sorry for the late reply... :)
Did you figure out which bolts to use ? If not, when you removed it, did you keep one of the old fasteners ? You know...just to use as reference. :D
JamesinAbilene
