Service Battery Charging System
zach2011
Platinum Member
This error came up on my dash a week or two ago. Didn't really bother me because it went away after driving for a bit. But then, on the way home from school, everything started shutting down one by one, like the radio and HVAC controls...lights were all dim, wipers moved slowly. So I pulled over at a gas station and had it towed.
Dealer calls and says it was battery, which I thought was weird since I have a YellowTop, but I exchanged it at AutoZone and this one works fine. Everything seemed great. But the problem came back today. Except this time it didn't kill the battery, everything ran fine but it still showed the message.
Can't be the alternator, I wouldn't think, as I have already had that replaced. So what else could it be? Is it possible I have a really bad wiring issue? :confused:
Monarkk
Banned
I have a yellow top as well and this has happened before, did you get an extended warranty on the battery or do they always take it back?
zach2011
zach2011
Platinum Member
Mine has an extended warranty, but they may exchange them anyways.
Monarkk
Banned
You have to show a receipt? I got mine at autozone as well. Wonder if they have it in the comp system...
OklabyGodhoma
Normal....er, Norman, Oklahoma
Zach, it appears you have been zapped by the dreaded GM power management system. Sorry to have to say this but it is something that needs to be hooked up to the stealership equipment. Hopefully a code will show up but doubtful. You have done everything right by using the Yellow Top but the way the system was designed it just doesn't charge the battery as much as it should so we are all constantly draining the battery bit by bit. The only way I have found to beat this is to put the battery on a charger about once a month and let it get a deep cycle charge. Good Luck!
zach2011
zach2011
Platinum Member
Thanks for the helpful info! I was thinking, is it possible that it's related to my iPod kit? Ever since I installed it, my temperature/compass part of my mirror doesn't work and the backlighting to my liftgate button went out (yet the button still works). Weird things. I'll uninstall it today to see if it helps.
Goodinblack
I Like Tacos
Dirty South
Any one else experience this.
Please advise ASAP
From my CB Radio.
chadman
I have a 2009 LTZ and I was getting this warning once in a while. My Tahoe only goes on short 20 min trips to and from work, so I am assuming its not getting a long enough run to charge up the battery. about 8 months ago I upgraded the battery from the stock GM one to a bluestar 770cca battery. The warning went away, but just came back the other day. I may hook up a trickle charger to it.
Goodinblack
I Like Tacos
Dirty South
Thank you for the reply.
So what causes the warning?
A electrical bug or is the battery really dies.
From my CB Radio.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
shit. Got this message tonight. Then again its 9 degrees outside. The good news according to my Alarm system that can read battery voltage. Its telling my that its 12v engine off and 14.8 running. Must be the battery
scottg918514
No warning light but issues. The other day, I was testing a rear defroster repair and had acc on (not started) and had a dead battery after 10 min. I had to jump start.
I hooked up a charge and charge to 100%. A few days later (today) I noticed the voltmeter fluctuating between 12 and 14 on an hour long drive (this may happen all the time, I was just paying attention today). I got home an decided to test the battery, said 56% charge,
I'd expect 100 after an hour drive. Bad battery? Or alternator. I don't know battery age, I bought used in 2013 (2007 truck) but no date codes marked on battery. However, it is a Carquest battery, so not original.
scottg918514
New battery seems to have fixed it. With the old battery, I noticed the voltmeter start at 14.3 then drop to 12.3 or so and stay there. I put in a new battery and now the volts stay around 14.
Incidentally, the old battery was a CARQUEST with "Specially designed for European autos" on it. Not really sure how you design a battery for American, Japanese or European cars, but either way why would you put that in a GMC (prev. owner).
Maybe the European batteries work with 220 v. :)
scottg918514
Voltmeter was staying around 14.5 constantly, but now dropping to 12.5-ish after a few minutes of driving.
Alternator?
shundal
NorCal
I've noticed my Voltmeter does that a lot while highway driving, think it might be normal.
It's normal. The charging system drops voltage when the battery is charged. It's supposed to put less strain on the alternator and help gas mileage.
scottg918514
Thanks for the replies, I put a new alternator on and still have the fluctuating voltage. I guess that is normal, oops.
mykon04
Porter, Texas
I noticed this as well. I just bought a 2008 LTZ and the voltage will fluctuate from 14 to 12. That does make since about backing the charging off to save fuel mileage. It seems everything else is designed to save mileage so I believe it.
Maximus56
I read an article that solved this problem. It was the positive cable, inline, 175 amp fuse that's in a box bolted to the fire wall. It's the branch of the positive that goes to the alternator. The fuse cost about $4 from Autozone. Replaced it and haven't had the problem since. Hope this helps.
SuburbanPassion95
