6 inches+ lets see your rig
holeshot
They are Toyo Open Country M/T 38x15x16's. It's got 11" of lift. I went ahead and had the ball joints replaced and 4 new shocks when I put the new tires on along with an alignment. I was going to with a bigger tire but they don't make a 40" tire in a 16" rim anymore. I tried a Irok 41x14.50x16 but it was going to hit the frame with a sharp turn. It was huge! Check out the photo I have attached. It was going to take a some minor trimming to clear the fender wells. There is just not a lot of options if you want to go bigger that a 38" up to a 40" tire if you stick with the smaller rims. I'm old school and like the ballon tire look. I tried an Irok 39.5 x13.50x16 and it is too skinny and was about the same height as the Toyo 38". On the next rebuild it's time to go with a straight axle and some 44's!
RedCrush
yup.. That cats wearing a cone sunlit....he's the talk of the neighborhood... random cars drive up to take his picture. Jack is a celeb...
mudslinger96
Anyone here running 37s with a 6" lift and no body lift? Based on these pics, it looks possible (he's running 36s). He does have the 6.5" Dick Cepek lift though, not sure how much of a difference .5" will make, especially when you can crank the keys. I'm installing the BDS lift since the Dick Cepek is no longer available. Thinking of going with some Toyo Open Country 37/13.5R17.
It is possible i was running my 37s with only the rcx 6" with no rub at all
Crowder99Yukon
OOOOO, I finally get to play.
Tahoe: Dick Cepek 6.5" set at 8", Bilsteins all around, 6" rear springs, 4.56 Yukons with Trutrac, 35x12.5"x17 Kumho Road Venture MT, 17x9 ATX Artillerys
Suburban: Rough Country 6", set at 6", 4" block with 2" AAL, crappy shocks all around, 4.56 Yukons with Trutrac, 35x12.5"x17 Procomp Extreme AT, 17x8 ATX Mojaves
That suburban is quite sexy
Sent from my HTC One S using Tapatalk 2
turk
The "Manhoe"
Barely a scratch on her yet. Looking to replace the exhaust soon. 6" BDS Lift. Fuel Octane Wheels.
jasonconway5
Lift?
No lift, but 285/65/18 Nitto Grapplers which did raise it 2" and I like the way she sits as is.
vsaravia
