what size tires ?
jb4x4
i have a stock 1996 tahoe with 285/75/16 they fit fine with no problem ,i'm about to put a 3" body lift on it and wanted to know if anyone had put 315/75/16 on stock rims and if they would fit ok with a 3" body lift :mexsmoke::emotions122:
bowtiefreak
No Quarter
Near Philly
I think they will fit with some trimming. If it were my truck I think a 305 would be a better fit with no rubbing and so on. the 315 will be tight!
sc00bz
South Paw
I would go with 315's n no body lift
bowtiefreak
No Quarter
Near Philly
315 with no lift is going to require a bigger saw...unless you only want to go straight and never hit bumps. your call on that one.
blackcoffee
O.G. Black.
I run 265/75/16's stock I think I could run 285's but!!! If your doin' some 4x4n' then your gonna be rubbin them pretty tires of yours. SO if you only have 3" of lift then I'd say 305's like B.T.F said TOPS.
---------- Post added at 09:03 PM ---------- Previous post was at 09:02 PM ----------
BTW don't cut into your pretty lil' hoe.. You may regret it.
CBR600F4
I have stock Size on the LTZ 275/55/20 i want to get a taller tire also wider but do not want to ruin stock ride. what can i go with any tips??? 305/55/20 OR 275/60/20???
So far For tires i found Nitto Grapplers. which Look OK so let me know what you guys have
THANKS!!!
bowtiefreak
No Quarter
Near Philly
CBR600F4, In order to fit them properly, you will need to crank the front up a bit. I had run a 305/65/16 in the past and they rubbed. Stick with thesize you have is m opinion
CBR600F4
alright cool, ill stick with OEM size
bowtie your truck is sweet man. I wish i had one of those too. i could run over all the cops.
Eickybobby5050
