Steering will jerk while cornering.
Kcbuckeye22
I have a 1999 tahoe 4x4 4 dr with 148k that has been the biggest money pit known to man. Once something is fixed it brings forth another problem.
I replaced the pitman, idler, gear steering box, sway bars, steering speed sensor (on the steering column), brakes, rotors, new rims, tires, and a alignment. Now believe me this truck drove horrible, I mean horrible, before I fixed all the above. Now it's so so and okay, however this truck has a jerk while Cornering. It's bad enough I almost lost control of it cornering 60 mph in the rain the other night with the family on board. Not fun. I can't imagine driving it in snowy weather this winter. It will jerk both ways and at any speed. I can almost guess when it's going to do it after putting 5 k miles on it, however sometimes it surprises me.
I've sunk way too much into this pit to sell it (bought it at $3000, $8000 total now) so I'm stuck with it for a few years. What do I have to replace next?
_Dylan_
STAY FROSTY
Everything you listed is basic maintenance items except the steering box. Unfortunately for you, it sounds like you've bought a truck that wasn't maintained.
The problem you are having now is a bad steering speed sensor.
K
Kcbuckeye22
I've replaced this. I did replace it before all other items were replace.
K
Kcbuckeye22
i say cornering at 60mph in the rain is your issue.
Posted speed was 70.
---------- Post added at 03:13 PM ---------- Previous post was at 03:10 PM ----------
this?
http://www.amazon.com/Dorman-905-51...rId=004&n=15684181&s=automotive&vehicleType=6
http://www.tahoeyukonforum.com/forum/showthread.php?t=22324
I don't know what to tell you. If the front end is tight, you might have to put a another new sensor in it.
Yep I replaced it. That one is at a better price too. Steering is fine other than the jerk. Not tight not loose.
---------- Post added at 03:14 PM ---------- Previous post was at 03:13 PM ----------
EVO on the power steering pump?? That's the next item I'll check out.
Tbruz
Windham NH
Disconnect the EVO sensor on the back of PS pump and drive around for a week or so; if the jerkieness is gone; problem is identifed. You can either live with no EVO assist(which is really full power assist at all times when EVO is disconnected) or locate a replacement sensor(NLA from GM) but can be found on rebuilt pumps from Cardone.
Tbruz
K
Kcbuckeye22
Tbruz
Thanks ill give it a try.
K
Kcbuckeye22
i say cornering at 60mph in the rain with a posted speed of 70 mph is your issue.
It does it at any speed. Wet or dry. A Vehicle with a jerk when turning /cornering isn't fun to fight. I'll try the above suggestion on the EVO, and disregard your driving critique.
_Dylan_
STAY FROSTY
They don't know what the hell they are talking about because they have a 95 and 96. The evo steering didn't start until 97. I have felt the steering wheel jerk and it scares the shit of of you. But mine hasn't done it in a long time, so I haven't bothered replacing the sensor or anything. I might unplug the sensor from the box and see if there is any improvement.
matthop53
Springboro, OH
I have the same problem and stumbled upon this thread today. I ordered the sensor and it will be here for me to install this weekend. I hope this fixes the problem. My issue is exactly as described feeling like you're hitting a patch of black ice then the truck making an aggressive turn into the direction you were already turning the wheel. It's especially frustrating when you're just making gentle turns around a bend and all of a sudden your headed towards the ditch.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I think you issue is exactly as described. feeling like you're hitting a patch of black ice then the truck making an aggressive turn into the direction you were already turning the wheel.
saif najd
I didn't understand the problem but what I have is when I try to park tge Tahoe the steering become very heavy so I need to shift from D to N and press gas to free the steering wheel again!
I just replaced the steering oil it seems much better but I know it will last few days only
Is this the same problem?
I did replaced the steering gears and ends
Tbruz
Windham NH
If you have EVO sensor on back of your PS pump, try disconnecting it and drive around/park.
This will give you full power assist regardless of your speed.
If this corrects your problem then find a replacment EVO.
If you still have heavy steering with no EVO connected your problem could be a failing PS pump.
If it is the pump; save yourself the pain of the rebuilt ones, get yourself a new one.
Tbruz
saif najd
Tbruz
Could you pkease tell me where can I find the EVO plug?
I will do it today
McFizzl
Broke as a Joke.
Fayetteville, AR
My truck does this! I thought it was just me jerking the wheel too much or something. But i can be turning right and the wheel just goes! Like all of a sudden it gives me full power steering and cuts it after a split second
jackal78
