p0449 part numbers
Most Hated
I have an 07 tahoe with the p0449 evap vent code. I have read conflicting info on the web about part numbers and needing to replace part of the wire harness that plugs into the solenoid. Does anyone know all the required parts and have part numbers?
Goodinblack
I Like Tacos
Dirty South
Since no one else posted....
I have not experienced said DTC code.
You mean to replace the harness not the solenoid right?
From my CB Radio.
M
Most Hated
Well from what i have read and how i interpreted it, i need to replace the EVAP vent valve/solenoid. And some people say that you need to replace a piece of harness as well. Im not sure.
LightningGA
Saratoga, NY
Part# 20995472 AcDelco Evaporative Emission Canister Ventilator Assembly
Part# 19257603 AcDelco Evaporative Emission Canister Valve Solenoid Jumper Wiring Harness Assembly
Here's a pdf version of the service bulletin and install instructions for the updated part numbers: http://ww2.justanswer.com/uploads/supermechanic/2012-08-17_235851_purge_valve.pdf
I just ordered the same parts from Amazon because I have the same P0449 code.
Hope that helps.
Sent from my GT-N8013 using Tapatalk HD
M
Most Hated
Well i replaced the evap vent solenoid amd cleared the code and the check engine light immediately came back on. Anyone know what else could be the problem? Also, does anyone know the voltages that I should have at the plug with the key off, with the key on, and with the engine running? Thanks.
GalaxyBlackEsky
BlackedoutLT3
MD
Just to let you know I am having exact same problem after replacing parts for that code. Also replaced purge valve on top of engine and also gas cap. Taking it in to dealer Sat to see what the hell is going on. I have a feeling it is electircal somewhere. So I will let you know if I can get the dealer to tell me.
M
Most Hated
Ok cool. I definitely think its electrical too. Im trying to find somone with a bidirectional scan tool that can command the solenoid on so I can check.
M
Most Hated
So did u get it fixed?
M
Most Hated
Anyone else know any other fixes? I really dont want to take it to the dealer.
02jeeperx
I know this post is over a year old but I am having the same issue and wanted to know if anyone had an update that may help me out. Any input will be greatly appreciated. Thanks
-B
:cheers:
jz57
To fix P0496 problem, you need following parts:
EVAP purge valve (GM 12597567)
EVAP vent valve (GM 20995472)
It is a easy repair job, but it takes long to time reset check engine light by PCM.
M
Most Hated
The thread is only a few months old. Lol. But I ended up taking it to the dealer. I told the mechanic my problem and what I did and he immediatly mentioned a common problem in the harness under the drivers floor. He put it on the hoist amd found a broken wire that supplys power to the solenoid. Repaired the wire and reset the code. Whole process took about 30 minutes start to finish. He said they run into that all the time.
Phlipnstik
