Cepek still available?
Filescreekmafia
Hello all
New guy here I just picked up a 97 Tahoe 4 dr and am looking to lift it. From what Ive read on here the Cepek 6.5 seems to be one of the better lifts for this truck. Are they still available? I have not been able to locate one online. I plan on running 35 MTZs on 15x10 wheels. Looks like I may have to go the RCX route. Thanks for any input.
Donnie Yukonie
Yates Caretaker
yea from what I've read they are no longer producing them however depending on your budget there are other great lift kits out there i went with super lift and honestly couldn't be happier RCX is a good lift for the money as well
F
Filescreekmafia
Thanks for the info Don. Superlift was my first choice but after doing some research on here I was leaning toward Cepek or RCX. The RCX seems to be a good bit cheaper too. My main concern is fitting the 35-12.50s on 10" wheels without cranking the TBs too much or doing alot of trimming.
Donnie Yukonie
Yates Caretaker
My cv angles are in the pic below , i bought the 6.5 inch kit but I'm sitting at 5 inches at the moment with a negative crank . i did have to trim a bit
mudslinger96
Don't see any problems with running 35s i have the rcx and i am running 37s with little rub at full turn when flexing. I don't suppose you would have to trim any to run 35s. By the way this kit is very solid and not bad for the price either i paid about $1400 with upgraded shocks, sway bar links, and steering stabilizer.
KPOD
Michigan
Did you have to install the new driveshaft?
redaddiction
If you want a Cepek kit check on ebay there is a place who is still making them.
Fishin757
VA Beach
i went on superlifts site and saw two 4-6" kits. thats just fancy talk for " 4 inch lift but you can crank to get six" right? i was wanting the 6.5" kit then crank to 7 or so.
Donnie Yukonie
Yates Caretaker
Yes you are correct one is a 4-6 inch lift with a 4 inch diff drop and 4 inch blocks
the other is a true 6.5 inch kit with a 5 inch diff drop and 5 inch blocks
this kit is the one i got and can easily do 7 inches I've seen a yukon and a silver ado get a full 8 inches out of these kits ….CV angle was high tho lol
Fishin757
VA Beach
this is from the superlift site "1997 and newer models with Autotrac require dual cardan driveshaft, shown in options. Non-Autotrac models may also need driveshaft if regularly driven in 4WD over 35 MPH."
Fishin757
VA Beach
basically. i think skyjacker includes one in their kits but im not positive
bowtiefreak
No Quarter
Near Philly
confirmed, cepek is dead. I broke part the other day and there is no spares out there. Thankfully I know a chassis shop near by that does monster truck frames...$40 and back in business.
I broke the bottom bracket for the dual shock set up. What a mess.
D Rollins
