1.5din or conversion...
buck51
anyone ever find a 1.5din or did they convert to a 1.5 din? need input
yukonese
not many choices
I think yours is pre 03 model, the head unit opening is about 3.3". I am looking for a DVD receiver for my 01 Yukon as well.
So far, I have these single DIN candidates with a little larger screen sizes, but still fit in (no flip-up please):
Power Acoustik PD-535
Power Acoustik PTID-4550T (2011 model)
Power Acoustik PTID-5000T (2011 model)
Sound Storm Lab SD555M
Pyle PLD45MU
Plus some no name models on eBay.
Not many reviews available for these models, except Pyle. I really don't want spend a lot of money/effort to install one of them, and find it broken in three months.
I try not to do double DINs, if these is a single DIN solution (not 3" screen though).
nhoj_yelbom
Pensacola, FL
a DD is not hard to install in the 1.5 din opening. requires removing cage and cutting the back off, DD dash bezel or trim original, 2 wood blocks bolted to cage for DD to bolt to. it goes back to stock by removing 4 screws and wood blocks
ebxgsxr
Baltimore, MD
hmm, i was thinking about something like this for my truck too. but i just tried searching crutchfield & nothing really came up.
ebxgsxr
Baltimore, MD
no one has done anything like this? i'm really thinking of doing something like this to avoid the extra trouble of installing a double din. but additional feedback would be appreciated.
godoy
utah
A DD will look so much better
Sent from my HTC VLE_U using Tapatalk 2
Twist Off
So to convert from 1.5 to DD trim the cage and use a '03 bezel? The HVAC control panel is the same?
ebxgsxr
Baltimore, MD
i used my original bezel, but a 03+ would not require trimming.
the 03 + bezel doesn't require trimming, but from what i've read you still have to modify the cage as the HVAC controls would have to come down a little in the cage. to require no trimming at all, you would have to get the cage & the bezel.
D Rollins
