2010 Yukon Denali Retrofit + Lighting Modifications
soulsea
Bar
Hi there,
So I've yet to do threads on all my individual lighting modifications, so I thought I'd consolidate the lot of them in one …
Headlight Retrofit:
Hardware (also including cost because people always ask me):
Projectors: RX-350 Bi-Xenon ($225)
Lenses: RX-350 oem lenses custom polished clear ($50)
Bulbs: Osram Xenarc SVS D2S 4200K ($200)
Ballasts: Morimoto 5Five (50W) ($110)
Shrouds: Type K ($50)
Harness: Custom/Dedicated and modified for daytime 'flash to pass' ($35)
Park/Turn signal: Osram Diadem 3457 ($20)
Side marker: Osram Diadem 194 ($10)
DRL disable (pulled fuse)
Housings: TYC oem replicas ($200)
Total hardware cost: $900 + labor $.
Installed/Executed by Bjorn at customlightz.
---------- Post added at 03:18 PM ---------- Previous post was at 03:18 PM ----------
Rear Lamps
Hardware:
Tail lamps: Escalade oem lamps, custom plug and play harness , Catz Zeta 7440 reverse halogen bulbs.
Upper mount/3rd: Oem escaped spoiler and 3rd, lamp custom modified by Faites777 on hid planet to full leds across.
If you wish to have you escalade upper mount lamp modified like this, you can contact Faites777 either via PM on hidplanet.com, or by posting your request on my build thread: http://www.hidplanet.com/forums/showthread.php?44342-Escalade-Full-LED-3rd-Brake-Light-Conversion
NathanJax
Vacation Nathan
Jax, Fl
Those headlights will be mine one day...
VTburban
Vermont
this makes me giggle. with excitement. i know that doesn't make it ok, but i'm excited about this. ehem, good work serge.
yates ™
Resident Apple hater
Iowa
Very jelly but Serge why do you not remove the orange lenses when you do these?
yates ™
Iowa
The orange would be the first to go if I did this.
soulsea
soulsea
Bar
Thanks peeps.
As far as the amber reflector, there's a reason it is there, so it stays.
But I did get rid of the huge yellow reflection from the amber turn signal bulbs by using diadem coated bulbs which disappear against the chrome ... same with the side marker.
And yes, I love things looking oem ... :)
brice715
