is this what i need for HIDs?
oreowizard98
Monroe NC
From the posts, I have decided to go with DDM Tuning's kit. I still want to run Black Headlight and Turn signal housings. Found several on Ebay. Not sure which ones will work from other chatter I have heard that HID's dont work as good with reflective backgrounds. Any advise?
DenaliAK
Colder than you
Alaska
If the HID is mounted in a projector, the background of the rest of the headlight is sort of irrelevant because the light from the HID shouldn't even be seen anywhere but where the projector is pointed. If it's in a reflector housing, you're going to get a ton of glare and blind people.
JamesinAbilene
