Ducati18
What are the best brand gears? What should I do about the front diff gears?
our is the 8.5/8.6 R&P (ring and penion)
Motive, OEM, etc all make good gears.
Facory gears coiuld be a varierty. Best is to run your VIN and try to decode it.
You may have 3.42, or 3.73.
Gear ratio depends on tire height, and RPM's you desire.
Auburn makes NICE lockers.
ever plan on getting 20's, and taller tires?
The 4L60e is electronic OD, so IMHO, I have 31" tall tires, 4.10's is perfect!
But if you can go drive on the highway, say set cruise at 55mph, whatever, log what RPM it's at. Then post tire size you have, we can get a close estimate on what gearing you do have.
nothing yet, still looking around![]()
Check your glove box for the following RPO's:
GU6 or 305 - you've got 3.42 gears
013, 054, GT4 - 3.73
Yukon 4.10s and a detroit trutrac out back, check out www.ringpinion.com for the gears and such.
