Where do you fill up?
CHOO CHOO
BackPagePhil
Manheim, Pa
Chevron w/ techron usually. When I first got the truck, I started w/ 2 tanks of 87, then 2 of 89, and lastly 91. Despite the price listed on the street markers @ gas stations I've realized a tank of 87 vs 89 vs 91 is only $4-$6 per fill up. Considering the trucks drive ability is supreme w/ 91, IMO, I just use that.
Yeah, I always use 92 or 93 oct. Like you said, its only a few bucks more so might as well have my tahoe drive better.
alc5m
Soulsea, I have to disagree with your article. If all the gas comes from the same place, then why do all the trucks look different and come from different refineries? I'm going to use Salt Lake City as an example because that is where I'm from. In North Salt Lake there are a few refineries, and each of them have their own companies logo that is visible to the public from a good distance away. These refineries are where the fuel that goes to gas stations is sourced from. If the gas is all the same, and comes from one source, why are there all these different refineries? Why did GM conduct its own testing and determiner who was Top Tier, and write a TSB on it? GM wasn't the only one. Mercedes and a few others did this too. It's just like the oil debate, are all oils the same? The answer is no. Ashland bottles Valvoline and Parts Master oil. Parts Master is cheaper. Why? It lacks some of the protective qualities as Valvoline, thus I would never recommend using Parts Master ATF type VI synthetic transmission fluid which is used in GM vehicles. Even if the gas did come from the same place, I would wonder why each refinery has a different holding unit for each type of gas.
each refinery has a different holding unit for their specific brand because each brand has markers in it to say that its that brand when tested by the government
edit:
place where i used to work ended their contract with BP because some BP branded station in like KY decided to run unbranded fuel, same stuff but they got fined up the ass for not having the markers saying it was BP fuel
Pain@thepump
sOuL-CaL
:Handshake:
I was going to try e85, but each station is 30min away from me in either direction, so I'll spend the extra dollars on pumping 91 locally, plus e85 is hype.
THE YETI
Director of Operations
South FL
I'm not entirely sure if I buy into that Serge. When Justin did my in person tune, even though I had 87-octane running in the tank, it was showing alot less of an octane actually being burned. First thing he asked was "where did you fill up at?" Then suggested going elsewhere because the octane wasn't burning at a true 87. Atleast that's how I understood it. But who knows... not that big a deal for me, truck runs good and gas is what it is.
boudreaux
Atlanta
QT. One near the house and one near the office. They usually get my business. However, if the chime dings, I start looking for the closest station around. I found out early that my doesn't ding just when it's low, a ding on my Tahoe means start looking for a station - NOW.
stevek
Dallas, TX
I have seen many of the same articles that soulsea is posting. The only thing I have read that is any different is that a few do not use ethanol (though it seems VERY few and perhaps getting to be none... Around here at least) and that seems to make bigger difference than anything else they do.
Reported ethanol free stations: http://www.buyrealgas.com/
Denali0229
Denali0229
FL
How does ethanol-free gas effect your engine? Do you get better gas mileage? Is it more expensive? I will be near one tomorrow. I should be near empty by the time I drive by there so I'm looking forward to trying it out. How do these stations get away with selling it, not sure if its a law or not? I noticed most are at marinas or near them so I'm assuming they are mainly for boats. There is only one inland but a ton near the coast. I also noticed some are service shops.
Peaches
Dirty South
Yes, real gas gets better millage, I actually think my truck runs better with it. In terms of price, it's like paying for premium v. 87. I don't even look at the price. The problem with ethanol gas is, there really hasn't been long term testing on it. And the current administration is trying to get ethanol bumped from 10% to 15% in gas. That really can't be good for engines.
Where on earth do you live if you don't have real gas?
I always get gas from the same station, I'm not necessarily picky as to brand, but I like to keep it at one station to isolate problems should they arise. Also, it has to be 100% gas, no ethanol, unless I flat out don't have a choice. I also avoid filling up, if the tanker truck is there. My grandpa insists that it's bad for your fuel pump, due to stirred up debris on the bottom of the tank.
Denali0229
Denali0229
FL
I live in Orlando. I went to the ethanol free station and they no longer sell gas. In FL, the stations have to have double wall tanks, piping, etc. so most stations had to have everything replaced. That could be a reason why they aren't selling gas.
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Ethanol produces less energy than gasoline. It is also more acidic, thus more corrosive, than gasoline. If a vehicle is not made to support ethanol it will run into long term problems such as piston rings failing and fuel lines corroding. With the Obama Administration trying to push E15 (testing is now complete on MY2007+ vehicles, and being conducted on older cars), and Cash for Clunkers happening back in 2009, I wonder why we are really on Ethanol. I don't know how many people I talk to that complain their 2 stroke yard equipment no longer works because of ethanol. Fortunately, an ethanol stabilizer fixes this problem. Lucas makes some. Because ethanol produces led energy than gasoline it also decreases fuel economy. There is actually much research done on the long term effects of ethanol. Ethanol is nothing new. The entire island of Maui got all of its electricity from an ethanol powered electric plant until sometime in the 1970s. Their ethanol came from sugar cane. Brazil is very dependent on ethanol fuel. It's cheaper and more accessible for them.
Tribological testing results on modern automotive internal combustion engines were provided by a university in Canada as early as 2007. Economic impact reports for the production of ethanol were provided by a university in Iowa several years ago. The gains aren't great. There is tons of scholarly information out there. You just need to look for it. I recommend Google Scholar.
stevek
Dallas, TX
The problem with the Ethanol is most cars that are 5 years or older aren't designed for it. The ethanol eats at the fuel lines and will corrode them away.
The reason ethanol is especially bad for boats is actually simple. When the gasoline is vented, the E10 attracts water. Boats are on water so it's rather humid. The gas tanks are vented (hence why you should run your blowers before you start up). Water in your fuel tank isn't good. Engines can get corroded, not start, sputter... dead in the water. Since autos are driven on a more frequent basis than a boat, they don't have this problem (plus their tanks are sealed until the car starts, where air is then pushed into the tank to give it some backpressure).
edgaranah1
Corona California
This sounds like you just copied and paste. Lol
But very informative.
Sent from my BlackBerry 8530 using Tapatalk
Peaches
Dirty South
^^ This explains why we just had to do $800 of repairs to the fuel system on our boat, because of the idiot before us.
edgaranah1
Corona California
Do you think he ever stabilized the fuel? I know I have to do this to my ATVs or else it means Im going to spend some serious dough.
D Rollins
