Paint Gun(s) recommendation needed...
jem556
KY
I'm looking for recommendations for paint spray guns to do small DIY bodywork projects. My Tahoe doesn't need work but other family vehicles have some bruises that I would like to repair. I have a Makita 2HP portable contractor's compressor with 2.6-gallon tank rated at 130 PSI, and delivers 3.8 CFM at 40 psi and 3.3 CFM at 90 psi (Will this be sufficient?). I would like to purchase some gravity feed paint guns for auto primer/sealers and 2-part base/clearcoat finishes. I don't want to spend more than I need to to get good quality results on smaller type projects (bumpers, panels, spoilers, etc.) Any suggestions (brands/models) from experienced painters will be appreciated!
JayXSP
Wallingford, CT
Iwata and Sata are your best bet...they're expensive but well worth the money. Coming from an autobody/painters background I've used and tested them all...cheapos to the best of the best.
If they're out of your price range then I'd go to your local paint supply place and see what they have to offer.
just my .02
AtomicHoe094
Atomichoe094
cleveland, OH
sata man here :)
Painting stuff is and will always be expensive.
Edit: heres my babies.. Primer gun, Touch up gun, base coat, and clear gun
04gibbstahoe
just my .02
+1
drkhrse00
Dallas Texas
Iwata and Sata are the ones I spray with. Sata for color ands Iwata for clear. If you hit some of your local pawn shops you might be suprised at what you can score on the cheap. YOu can get rebuild kits from your local paint supplier.
Ceejkay
Ft. Lauderdale, FL
i like the Iwatas as well. ive used many different guns and those are my favorite.. i even have a matching airbrush gun.. heres my gun
vsaravia
