Will not start and keeps blowing # 20 (prnd21) fuse when shifting out of park
How many times has a shade tree mech got you into a bigger bind than when you started
  • Total voters
SunlitComet
OBS Jedi-Do Good
unknown at this time.
not necessarily and if it was broke it would either not unlock when ignition power is off or would lock if the ignition was off. The key out lock of course locks everything. I don't see the part itself capable of an effect on what is going on at this time.
This is if things if things are normal:
Description and Operation When the Brake Transmission Shift Interlock (BTSI) is energized, the Solenoid locks the Shift Lever mechanism in "PARK". When not energized, the BTSI Solenoid returns to the unlocked position.
The Components involved in the BTSI Circuit are as follows:
  • Park/Neutral Position Switch
  • TCC/Stop Lamp Switch
  • BTSI Solenoid
Fuse #16 (Turn/Back-Up) supplies B+ (12V), after the Ignition Switch, to the BTSI Solenoid via the Park/Neutral Position (PNP) Switch and the TCC/Stop Lamp Switch. With the key in the "RUN" or "START" position, the Shifter in "PARK", and the Brake Pedal released, the Solenoid is energized. This locks the Shift Lever in "PARK".
Important:
  • Note the BTSI portion of the TCC/Stoplamp Switch (Pins C & D) is CLOSED with the Brakes released. Depressing the Brake Pedal OPENS the Switch causing the Solenoid to de-energize, unlocking the Shift Lever. The BTSI portion of the PNP Switch (Pins B & C) is closed in "PARK" only. The Circuit is not active with the key "OFF".
Because you can start the vehicle by bypassing the large wiring harness going thru the bulkhead and it is affecting the shift indicator going thru the sam haness for about a foot or two I think you will need to address that. I will post the bulkhead pin-out below for you to sort thru for starters.
BTW the harness tape will get your fingers sticky.:)
Harness Connector
C100
Notes
62392525
C100
Pinout Description
C100
Notes
62392526
C100 (Part 1 Of 2)
Notes
62392527
W
William Mosley
What is the shiny box with two sets of wires going to it? Behind the dash or in the dash so to say. Its next to the steering column. Looks likemsome kind of module or computer or something.
2nd Question: if my truck was driven with the main transmission wiring harness and part of the nuetral position switch wiring harness ripped out of the truck, from the 4wd driveshaft, would this short something out in my trans? Or something else in the truck?
Could this be my problem?
Found out the mechanic did not properly secure wiring harness before test drive after install of trans. And ripped them out.
SunlitComet
OBS Jedi-Do Good
if it has yellow connectors that would be the airbag computer. other wise it would be the transfer case control module.
Uh, yeah. definitely a possibility.
Put another harness in and retest.
W
William Mosley
If I put in a new wiring harness, how do I tell which wire goes to what?
There are several wires that are the same color and size.
I think this is what is wrong now, i think there are wires put back together wrong.
How would I go about narrowing down what wire is wrong?
Could something electrical have gone bad inside the trans. From running it without all the wires hooked up to the trans? Or wires that might have touched together.
---------- Post added at 02:14 AM ---------- Previous post was at 02:09 AM ----------
What do you mean a possibility, the metal box or the truck driven with some of the wires ripped out.
---------- Post added at 02:16 AM ---------- Previous post was at 02:14 AM ----------
Oh, by the way a really appreciate all the help you have given me thus far. :)
SunlitComet
OBS Jedi-Do Good
Possible it can short something. But mostly likely just a plain wire that may be grounded. Generally if wires in the tranny are not connected certain functions will just not operate. But you get codes for those as well. If a solenoid say got triggered from power getting to it when it should not have it would just sorta like activate it function. How the tranny reacts is dependent on what the tranny was doing at the time and what function was triggered.
Give me the connection end points of the wires you want to identify and I could come up with diagram and connectors views.
W
William Mosley
The wiring harness was replaced from back of the transfer case including the o2sensers all the way to the back of the motor. Including the main trans. Harness asmwell as the neutral position switch on the side of the trans. A color coded diagram would be nice.
Mabe one or two of the wires was put together backwards or in the wrong spot all together. I mentioned before there are several wires the same color and the same size.
I tried swapping around the same color wires but with no success.
I got the dash almost completely out now. It's 102 degrees now everyday now and with no shop or shade work is kinda slow. Plus it's my birthday today :) so I work on it some more tomm.
Btw thx for your help you really seem to know your trucks.
SunlitComet
OBS Jedi-Do Good
The diagrams won't be color coded in color if that is what you mean. They will be like others I posted. The do have the wire color printed on them along with the circuit number and gauge along side each wire. Is that okay?
:signs131:
Mine is Wednesday.
W
William Mosley
Isn't being a Leo great:)
---------- Post added at 12:06 AM ---------- Previous post was at 12:05 AM ----------
Those diagrams will be fine.
SunlitComet
OBS Jedi-Do Good
Transmission and Drivetrain
Notes
62392563
Light Duty Transmission/ Heavy Duty Transmission
---------- Post added at 11:51 AM ---------- Previous post was at 11:50 AM ----------
VCM Power and VSS
Transmission Controls
Notes
58833730
VCM Power And VSS
---------- Post added at 11:51 AM ---------- Previous post was at 11:51 AM ----------
Brake Switch and Solenoids
Notes
58833731
Brake Switch And Solenoids
---------- Post added at 11:52 AM ---------- Previous post was at 11:51 AM ----------
TFP Valve Position and PC Solenoid Valve
Notes
58833732
TFP Valve Position Switch And PC Solenoid Valve
---------- Post added at 11:54 AM ---------- Previous post was at 11:52 AM ----------
there is a quick starter let me know what others you may want. BTW you have the light duty tranny(4l60e).
W
William Mosley
Ok, I traced one of the two Pink wires coming from the #20 fuse. The pink wire going to the instrument cluster is fine. Any idea where the second pink wire goes so far it goes somewhere under the truck to the trans?
SunlitComet
OBS Jedi-Do Good
down the transmission harness to cavity E in the harness connector shown on the left. Remember the connector is keyed for reference.
Notes
62392563
---------- Post added at 08:35 AM ---------- Previous post was at 08:24 AM ----------
One more for you for the inside of pan.
Notes
58833731
W
William Mosley
Ok there is not any wire that I have not inspected. All wires are in good shape and none of them are grounded. So it only can be either a wire put in backwards or mismatched or one or some of the electronic copoments inside the trans has gone bad. I was told if the main trans elec plug was not plugged in the truck would not start. So it's got to be some wire that goes to that plug or something inside the trans that the plugin goes to. There are two pink wires in that plug one of which goes to the fuse that keeps blowing when shifting from park.
Do you know of a diagram that specifically shows where those two pink wires goes and there function?
If not I have to just swap wires around til I find what goes where, and there are to many combinations to figure out. I just want to pull my hair out and take a 30-06 to my truck,
This is so frustrating I have had this truck since last July and I have drove it only 4 times .
SunlitComet
OBS Jedi-Do Good
Me? I only have one from my own truck not being finished. And the severe lack of money because of no job to do what I want with it.
William is probably readying a hair transplant just in case.
Gzes
the drifting 2dr
Wichita tx
Have you gotten anywhere with you motor problem? And yea William might be ready to push it off the neareast cliff or accidentally get it torched by an unown person and just get the insurance money and get a good down payment on a new hoe;) jus kiddin but it sucks to have that bad of a issue. I would say **** it and probably kick a dent into a junk car I got in the back:)
W
William Mosley
Yep, it is a pain but this is such a nice truck I don't want to give up on it!
---------- Post added at 08:44 AM ---------- Previous post was at 08:32 AM ----------
Why does your diagrams keep changing every time I come back to this site? I need that one showing what to test ohms on the round tran elec plug. and the one that shows what to test the volts on the trans position plug. It's rectangle in shape. If you can get those up again I would appreciate it. Thx
---------- Post added at 08:57 AM ---------- Previous post was at 08:44 AM ----------
The fuse box under the hood has a red wire coming from undrneath the fuel pump relay. The wire has what seems to be a factory plug in at the end of it. The wire is only five. Inches long do you know what this is?
SunlitComet
OBS Jedi-Do Good
Automatic Transmission - 4L60-E
Electrical Specifications
Notes
83368108
Connector was used by factory during building to prime the fuel system during it first gas up and start otherwise they would have to mess with the ignition for too long. After adding fluids to the vehicle it moves down the line to receive its battery. As it goes down the assembly line they power that wire for a while to bleed all the air out of system. That wire can power the pump thru the relay when the relay is not energized. By the time it gets it battery it is primed and ready for a flawless start and roll out.
(Base And Luxury) (Fuel Controls)
78553822
---------- Post added at 03:52 PM ---------- Previous post was at 03:48 PM ----------
The pictures change randomly after a few hours. I can make them permanent but it takes to long to post So view them in an enlarged state and print them. Also but letting them change new users who might need them will have to register and ask for them again and that could help bring more users to the site not to mention maybe even monetary support for the site.
W
William Mosley
Ok I just found out the reverse lights do not work. Could this have something to do with my problem?
Drewphil
