LQ4 or LQ9
renaldo99
Im ready to swap my motor and i know ive read about these 6.0's but cant remember which is a better choice that will work great with my setup..
renaldo99
renaldo99
low comp allows far more boost.
LQ4 unless you are wanting to build a fordged bottomend.. to run high comp and a fair amount of boost..
How much more boost can i run with a LQ4? im at 10lbs now on my 5.3
renaldo99
renaldo99
tottaly dependent on your tune, and how like the pistons hold....
r these the only motors that will swap with my Tahoe? Can the tbss motor swap right in and work with all my bolt ons?
ezdaar
Chat Troll
Redneck central, Aka Houston
the short block can, but nuthin else is pure plug n play.
You would be bes off, ARP'ing rods, crank and heads and swapping in some good pistons into a LQ4.
You will push that 1900 close to max.
renaldo99
renaldo99
Oh ok got you..
Doesnt the LQ9 have more HP then the LQ4
renaldo99
renaldo99
NA, yess.. its a point or 2 higher in comp..
But you have a TVS1900, lower comp is ideal for higher boost that your looking for...
wouldnt it be the same HP as the LQ9 if i put the LQ4 with a lil more boost and get a safe tune without blowing it up ??
JKmotorsports
Austin, TX
If your tune is spot on, you can run an LQ9 with the boost you're running now. I'm running about 9.5 to 10 psi with my afr around 10.9 wot on my LQ9 for about two yrs. In cold weather, I've been up to 12 psi without any detonation or issues. Make sure you use good quality, high octane fuel and your tune is as close to perfect as you can get it.
Generally, lower cr is better for boosted apps, but if the tune is right, you shouldn't have any probs. I'd say go for an LQ4 for the safety margin, but I wouldn't pass up a good deal on an LQ9 if you find one.
renaldo99
renaldo99
Ok Ive totally changed my mind!!!! With the money i would spend buying a new reman LQ4 or lQ9 with install will be a waste of money for only 45-50hp tops...
SO ive decided to either get a 408 LQ9 short block or a 421 LQ9 short block and bolt all my stuff on to it.. I will be getting alot more Hp with almost the same amount of money with a stock LQ9 swap
Tahoewhat
Ballin' on a Budget
TX
Nice. Cant wait to see which one you get, heck either one, i want to see vids after. lol.
