3.73 or 4.10
la tahodida
palmview tx-chicago il
Looking into getting gears
setup so far 2001 tahoe 4x4 not original rearend 5.3 fbo 220/220.581 112lsa tb stall long tube headers built trans catless.
Truck is driven from tx to indiana cuz i work in chicago so mostly highway miles is my concern will 4.10 be that much of a difference in gas than 3.73 tires r 295/35/24 any info appreciated
chip
Cincinnati
Good question. I've been trying to figure that out myself.
Jay
The difference in mpg for these two gears is almost negligible... maybe 1mpg at most. The reduced low-rpm efficiency of a larger cam will cost more than that.
The metric size you list corresponds to a 32.2" tire height. Is the 15.3 1/4 mile time you list with the current mods? What was the trap speed? For simplicity's sake I'll assume 100mph for the remainder of the discussion.
You have two directions to go here... you want better highway efficiency/manners or do you want better dragstrip performance?
Using a gear calculator, your current setup (32.2" tires with 3.42s) cruises at 75mph turning about 1900rpm, correct? With 3.73s you will cruise at 75mph turning about 2050rpm (which is the same as a 2004 yukon with 3.73s and 31.5" tires... the ones on the 17" factory wheels, including Denalis). With 4.10s you will cruise at 75 turning ~2250rpm. A little more noise will be present, but depending on your exhaust you many or may not get drone at these rpm. Drone will drive you crazy on long drives since the distorted wavelengths will act like a constant base sub vibrating in the cab at an annoying rate.
At the dragstrip, 3rd gear with 3.73s at 100mph is turning about 4k rpm. With 4.10s 100 is at 4300rpm. For best performance you want to cross the line at 2-300rpm past your hp peak rpm in the direct gear which is 3rd in a 4L60E (I call this out due to the limited gears and wide gear spacing like the 60E has). If your cam and mods peaks on the dyno at 5800rpm (typical of a 220/220 cam with non-ported heads), you want to be crossing the finish line turning about 6000rpm at the top of 3rd gear... which to do that you will need to drop the tire height down to about 30" and run a 5.13 gear, or a 28" tire with 4.56s... both give approx the same running ratio. In the case you have two sets of tires and the ability to program the PCM on the fly for the new size to get the shift rpm/mph correct (the 28"/4.56 track setup for reference), then on the highway your 32.2" tires with 4.56s will turn 2500rpm at 75mph. You might not like this many rpm on the highway as it will be louder.
As a side note, if you did change to 28" tires and 4.56s for dragstrip use, your 1/4 mile time would drop 5 tenths, easy.
As you see there will have to be some major compromise on the two different goals at hand.
This probably isn't an option, but I'll throw it out for you to consider.
The only real way around this is to swap in a 6L80E and run 3.73s or 4.10s. The 6L80E has a much wider and deeper gear range that will give you loads of launch torque with narrow shift extensions during the run. For example, a 4L60E's first gear is a 3.06:1 ratio and with 4.56s you have a 13.95:1 launch ratio. A 6L80E has a 4.03 1st gear and with 3.42s has a 13.78 launch ratio. Correspondingly, the 6L80E with 3.42s in 2nd and 3rd gear closely resembles a 4L60E's 2nd and 3rd gears with 4.56s (simple math to get total reduction). You will cross the line in 3rd gear, but again, the 6L80E has much deeper gearing to compensate for the taller tires and gears. The gear calculator shows 32.2" tires with 3.73s and the 6L's 0.67 6th gear ratio will cruise 75mph at around 1980rpm, close to what you currently turn with the 4L60 and 3.42s with your tires. It will take a heap of work to do this swap in an 01 though.
chip
Cincinnati
This ^^ is a ******* awesome post! Thank you for that!
I'm running 22x9.5's with 305/40/22's. I want to go as high as possible in the rear end, without losing my ability to maintain some decent highway fuel economy (I drive on the highway a lot!). What is the highest gear you would put back there?
Thanks again! Jay!
Wow Jay! Nice write up there. :High 5:
Jay
It mostly depends on what your personal rpm tolerance is. Your current tires are 31.6" tall (same as the factory setup with the 17" wheels).
Gear calculator shows these relationships at 75mph:
3.42s: 1900rpm
3.73s: 2080rpm
4.10s: 2280rpm
4.30s: 2400rpm
4.56s: 2520rpm
4.88s: 2720rpm
If you are 4WD, with 3.42s you probably average 18-19mpg at 75. With 4.56s that will drop to 15-16mpg due to the higher rpm. It takes the same amount of power to maintain the speed, regardless of rpm and gear ratio, but with higher rpm comes more pumping losses... meaning the engine is having to consume more fuel at 2300rpm to give the same power output since it's having to do more work to move a higher CFM flow rate of air versus turning 1900rpm.
For example, in the same truck, a 2500HD let's say, the 6.0L with the 4L80E and 4.10s (factory setup) will get ~15-16mpg at 75mph. It's turning 2500rpm to maintain this speed in OD. The 8.1L vortec with the allison trans and 3.73s, despite being almost 140 cubic inches larger, will get roughly the same mpg (14-15) at 75. But it is turning close to 2000rpm to maintain 75mph. The 6.0 at 2500rpm is consuming fuel close to the rate of the 8.1L at 2000rpm at this speed. Pumping losses. I know this is true because I've owned a dozen or more of these trucks with these engines and my records show the 6.0 and 8.1 getting roughly the same mpg on the highway. Now, in the city, the 8.1 uses more fuel since it takes more fuel to idle the larger cubes, but my crews spend most of their time on the highway.
rich5368
Cheyenne, WY
Tire size plays a big role. I have a Denali with stock 17 inch rims and stock tires with 3.73s and at 75 I turn identicle rpm to my bother in law who has 32 inch tires with 4.10s in his suburban.
chip
Cincinnati
3.42s: 1900rpm
3.73s: 2080rpm
4.10s: 2280rpm
4.30s: 2400rpm
4.56s: 2520rpm
4.88s: 2720rpm
I checked my RPMs @ 75mph yesterday, and I noticed that I'm right at 21-2200 @ 75mph (with a true speedo).
Does that tell you that I have 3.73s or 4.10s? (FYI: I have the tow package on a 4.8L)
Thanks again Jay!
03TahoeZ71
Minnesota
Thanks again Jay!
Look in your glove box at the RPO code.
GT4= 373's
GT5= 411's
Jay
The tachometers on these trucks are off a little bit. 31.6" tires with 3.73s at 75mph corresponds to about 2080rpm. 4.10s would be close to 2300rpm at the same speed.
I'll assume you have a 2004 or older model, where 3.73s were standard on the 4WDs and optional on the 2WDs (3.23s standard on 2WDs). 05-06 model 4WDs could only get 3.42 or 4.10 from the factory, while 2WDs could only get 3.23s or 3.73s.
Denali's got 3.73s in all years 06-older.
chip
Cincinnati
GT4= 373's
GT5= 411's
So check this out: Right after I posted this, I just happened upon a totally seperate thread just in time for this same discussion. I'll try to find it again, but somebody (forgot who....sorry!) posted up all the glovebox gearing codes. Mine is an '03 GU6 (3.42).
Thanks again guys! I really appreciate all your help!!
Here it is: http://www.tahoeyukonforum.com/forum/showthread.php?t=25387
Rook1979
Hey was wondering if a 2003 denali rear end will fit a 2006 silveado with tow package? Any help would be much appreciated! !
Rook1979
Can anyone tell me if a 2003 denali
rear end will fit a 2006 silverado w/tow package?
CKendrick
