Service trailer brake system
Darbogast
I have a 2015 Yukon XL Denali with 19K miles on it. It is stored indoors in a climate controlled area. In the past couple years the “service trailer brake system” message comes on frequently, and is a royal pain in the butt on a 2hour trip. As such, it gets driven even less that it has been historically.
I’ve changed the trailer brake module out, inspected the ground connections and checked the multi-pin connectors, etc., etc. I am an electrician by trade and am at a loss on what to do next.
I am reluctant to take this to the local GMC dealer as they always seem to just start changing out parts until they finally remove the problem thousands of dollars later… Does anyone have any thoughts on this or a remedy that works? I’ve only towed my fishing boat with this vehicle once. Is it possible to simply de-program the trailer brake system all together?
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
I cannot personally assist you with your issue, as I don't tow anything with brakes, but other members of this Forum much more knowledgeable than me in this area will chime in.
I did, however, out of curiosity, ask Dr. Google to weigh in on your issue.
Even after replacing the module, a "Service Trailer Brake System" trouble message in a 2015 Yukon XL Denali can be caused by corroded or damaged wiring at the rear 7-way plug, a faulty solid-state relay near the fuel tank, a weak battery, or dirty grounds.
The message indicates an electronic communication or electrical resistance failure in the Integrated Trailer Brake Control (ITBC) system. Common remaining issues include:
  • Rear 7-Way Connector and Wiring: Corrosion, moisture build-up, or spread terminals in your rear bumper's trailer plug are highly common culprits. Also, inspect the wiring harness directly behind the plug for pinches or exposed copper.
  • Solid State Relay (SSR): While you replaced the main trailer brake control module, the system also relies on an SSR (often mounted on the driver's side frame rail near the fuel tank). If this relay is corroded or faulty, the system will continue to throw the error.
  • Battery and Alternator Voltage: The trailer brake system is highly sensitive to voltage drops. If your battery is failing or has poor connections, modules will drop offline. Check your battery voltage and clean your main ground straps.
  • Damaged Main Harness: Check the main wiring harness running along the frame rail for rub marks or breaks, specifically where the harness connects to the chassis near the spare tire.
  • In-Dash Controller: The slide switch and gain adjustment module mounted on the dashboard can suffer from internal failures that prevent signal recognition, even if the rear module is new.
jaxscuby
Jacksonville, FL
my 2016 Tahoe likes to display, service trailer brake system, abs (pump rod stuck) & stability.
do you have abs light as well?
I read the codes and clear them, but going to replace the actual mechanical portion of the abs
and reuse my electrical portion, so no initilizing.
most the modules have to be initilized to talk to the Body Control Module(s), so it can read the data correctly from the module that
is sending information.
D
Darbogast
D
Darbogast
Thanks for the feedback. The Yukon has spent the majority of its life in the shop undercover. Has only pulled a trailer once without trailer brakes. The battery is newer and is typically on a trickle charger. I’ll dig into the ground connections again and will probably replace the dash board controller.
D
Darbogast
cwing
