Are LED Headlight Bulbs Worth Upgrading To? Seeking Real World Advice
dntnvme
Hello everyone.
I recently started considering switching my car's factory halogen headlights to LED headlight bulbs after hearing so many positive things from fellow drivers. My main concerns are brightness, lifespan, and ease of installation.
I drive frequently on poorly lit rural roads at night, so visibility is genuinely important to me.
However, I have read mixed reviews online. Some people claim LED headlight bulbs cause glare for oncoming traffic, while others swear they are a game changer.
Has anyone here made the switch? Did you notice significant improvements in visibility? Were there any compatibility or flickering issues I should know about before purchasing?
D
dntnvme
Hello everyone.
Has anyone here made the switch to these are the brightest led headlight bulbs? Did you notice significant improvements in visibility? Were there any compatibility or flickering issues I should know about before purchasing?
thanks in advance for any help
CMoore711
There are a ton of options for upgrading your headlights for increased light output, performance, and life-span/reliability all ranging in price, performance, and ease of installation.
You should think about answers to questions like how much $ you’re willing to spend, how much you’re willing to modify or not modify, and how much more light output performance do you want.
A good place to start would be to post your current vehicle make, model, trim, mileage, and headlight set up that you have now. Still running OEM stock bulbs etc and have never replaced them in X years or X miles; Tell us.
That type of information is required for other members to know in order to provide better advice direction and input. Without those details then any recommendations will be generic and may or may not apply to you and your vehicle.
Help us help you.
Meathead16
I've tried a few different LED headlamp bulbs and found they left much to be desired. Light output was drastically reduced.
I think it comes down to the housing and how most led headlamps have the light output on either side of the "bulb", which is shaped like a duck bill switch. The housings are reflective type and are designed for a bulb emitting light light in every direction, not just 2.
That being said, I've put LEDs in for everything but my headlamps and enjoyed increased output from them. They are also the cob type with some 25 leds per bulb or something like that to achieve that full coverage light output to match oem reflector housings.
I'm sure the right bulb with the right housing would yeild better results as far as headlamps go.
RST Dana
OH
16,17 and 20 all converted to LED headlights. I never had an issue after adjusting correctly and no one was ever “blinded by the light”. (Old school music reference)
Marky Dissod
I'm sure the right bulb with the right housing would yield better results as far as headlamps go.
It'd be interesting to compare OEM LED headlight housings vs aftermarket LED bulbs in non-LED housings,
to better understand why the latter usually don't meet (much less exceed) standards or expectations.
Til LED headlight bulbs catch up, I'll stick with HIDs. Note that some achieve better light patterns than others.
Try not to blind oncoming cars, please.
On that note: Although some prefer 6000K (color temperature), I prefer 5000K or 4500K.
If everyone else did, it'd be better for everyone's eyes - but I DEFINITELY see better in the rain with 4500K vs 6000K.
ReaperHWK
I have a 2026 Tahoe that comes with factory LED headlights. I have had cars in the past with HIDs and to me the HID were brighter…….
If I was doing a retrofit I’d go HID.
Marky Dissod
I have a 2026 Tahoe that comes with factory LED headlights. I have had cars in the past with HIDs and to me the HID were brighter.
Mind if I parse this?
Where the HIDs brighter? Or, did they throw a superior light pattern?
Or was it both?
ReaperHWK
Or was it both?
Both. Lots of articles and tests on LED vs HID.
The hids are in projector housings and use a cutoff shield for the high beam. They have a good cutoff.
LED headlights are better for overall for life, temps, and they are “faster” meaning how they turn on and switch from high to low beams are almost instant.
But for pure brightness I think HIDs have been tough to beat with the high wattage bulbs.
I’d say my Tahoes led headlights are good but not exceptional.
RST Dana
OH
Just remember, LED opinions may be like posterior openings, everyone has one, but most people favor their own. Just make sure your purchase has the “return” option in the event you are not happy.
Hello everyone.
Long story short, you get what you pay for, at best.
My entire truck is converted to LEDs, inside and outside. I am perfectly happy with my entire current setup. I live in a rural area with no street lights anywhere, and no shoulder on most roads. So, good visibility is essential, so that you don't drive into trees right alongside of the roads, or hit a deer suddenly crossing the road in front of you.
I've used a couple of LED headlights, and my current preference is the GTR Ultra 3 LED headlight, but they are pricey (for some) at $289.00, but they carry a lifetime warranty. I purchase all of my LEDs through headlightrevolution.com, as their folks are really helpful, and their prices are reasonable.
When purchasing headlight LEDs, make sure that they are adjustable, so that you can guarantee that you can adjust them to get a perfectly level beam. A perfectly level beam, combined with the proper headlight housing vertical adjustment, will yield NO blinding of oncoming drivers.
ReaperHWK
I had some time on a dark road by myself. Here is what a 2026 Tahoe looks like with factory LEDs. I’d classify them as way above average but not the best I’ve ever seen.
Low beams:
High beam:
A good HID setup looks like that except probably 25% brighter.
But I’d argue if your not some kind of light freak the LED is just fine.
ZKWBQD
Hello everyone.
Avoid anything that looks bluish. I put in LED lights once they had a slight blue tint. People were constantly flashing their high-beams at me. Yes, the lights were aimed correctly. I went back to the factory lights, the disco show stopped.
Tahoecrewcar
Hello everyone.
I waited a long time before making the switch on my 2019 Tahoe Z71 from the OEM halogen bulbs. LED technology has definitely improved over the last several years, so I'm glad I waited as things developed. About 2 months ago, I switched my low beams over to Lasfit LS Plus LED bulbs based on another members recommendation. I can tell you that the beam pattern is perfect and matches the factory halogen cutoff perfectly. The amount of light hitting the road is a night and day difference (no pun intended). I've always struggled with these stock halogen headlight bulbs at night, so it's really nice to see such a plug and play solution that actually worked perfectly.
As others have mentioned, clocking the LED bulbs correctly is crucial. The LED diodes need to be at 3 and 9 o'clock for light to correspond correctly inside the stock housing. It's also equally important to make sure that whichever LED bulb you use has the position of the LED diodes in the same relative space as the OEM halogen bulb filament. If the LED bulb chip placement is too long or too short, it compromises the pattern and output. It's for these reasons that I went with the Lasfit LS Plus LED bulbs. For about $100, it's a fantastic solution to the poor visibility from the OEM halogen bulbs. I can see the road MUCH better and I've yet to have any oncoming drivers high beam me.
wilcfr
Hello everyone.
I installed some on my Express van and took them out and put the HIDs back in. They were brighter, but didn't throw as far. Also thought they had a better near spread, but I need distance not width. They are cheaper, easier to install, last longer and use less energy, but to me it's about lighting up the road.
DrummerDude70
I have an '02 Tahoe that I upgraded years ago. I replaced housings and went with HIDs over LEDs. MUCH better results. I didn't read all of the previous responses, so forgive me if I repeat something already said. It's VERY important to have the cutoff shields in your housings. That will eliminate any glaring effect, provided your lights are aimed correctly. HIDs for the low beams, LEDs for high beams and fog lights. I talked directly to a rep from TRS (the retrofit source) for recommendations. That was about 8 years ago with zero degradation on the HIDs. When aiming your new lights, mark on a wall approx. 25' both your low and high beam bright spots. I aimed for a good average and have been VERY pleased with the results. Best of luck and cheers!
LsHart
Senior Member
LEDs draw less on the system. Always a better option. But gotta make sure ur circuit is able to run them. Aka led relays or bulb transducers.
Bigburb3500
I haves used Temu LEDs in my 2018 suburban and my 99 Toyota. Easiest and best upgrade you can do. Try the Temu ones and if you like what you see then consider upgrading to more expensive ones. I have not seen a reason to spend anymore as the cheapos work well for me. I also added a set of Rigid LED (SAE approved) fog light pods behind my grill. Combined, they are great.
Mannix2019
I replaced headlight and fog light bulbs with Lasfit LED bulbs. Completely plug and play no issues.
Extremely satisfied with light output, low beam cutoff, etc.
Very affordable at $70 for 60 watt pair of headlight bulbs, $130 for the 130 watt bulbs
Jetskier77
Headlight Revolution is an amazing source for information. He does a really good job at explaining why just slapping one type of light technology into a housing designed for another type, is not always the best idea. I was able to install some good quality LEDs into an older Suburban (2005) with great results, but in all honesty, there was a bit of bleed-over to oncoming drivers, so I had to keep them adjusted a little bit lower than preferred. My current vehicle is a 2017 with the HID option. I would love to improve upon these lights, but I know it will be difficult to find something that works well within the HID housings. The best bet is to go with a housing that is designed for LEDs, but yes, they can be very pricey.
jkhuntzinger
