my hoe is sick mayne real sick
texaschevyryder
LAWTON,OKLAHOMA
ima gonna put up a video cause i cant explain whats goin on wit it all my hoe experts and mechanics give me a shout out but ill descibe it til i put some clothes on and go out side its a tapping but know sounds like a knock
TahoeGoBoom
blue interior guy
a knock? like rod knock? is it worse when you rev up? not good at all..
AtomicHoe094
Atomichoe094
cleveland, OH
Hey glad to see you made it to the real forum... still waiting on your vid... doesnt sound good unless your kidding...........................nope you wernt kidding... .
Sepiroth
I am here
Kouts, In
Alright what you do next is take your serpentine belt off.
Start your engine again.
If the sound is still there, you'll need to invest in another engine or rebuild the one in there now.
It would also be a great time to do a 383 engine swap.
Sepiroth
I am here
Kouts, In
IIRC there is only one belt on your engine. You'll need to relase the tension of the belt tensioner to give the belt enough slack to pull it off .
I wanna say a 3/8in ratchet end will work in the hole. If not, youll need to use a 1/2in ratchet to release the tension.
Also, have you checked your oil level?
jmildoc
Indianapolis,Area
check your oil!!! Also my car did that same sort of noise one time and I thought it was a rod or something and it ended up being the pipe on the EGR valve was broken... so check out your egr too...
texaschevyryder
texaschevyryder
LAWTON,OKLAHOMA
oil level seems to be fine i checked this morning have not driven it does anyoen have any visual aids so i can better know what im doin i can do it jus wanna make sho im doin the right thing
---------- Post added at 01:59 PM ---------- Previous post was at 01:52 PM ----------
i checked oil seems fine i hope it is the egr speaking of what is the egr and where is it located
Sepiroth
I am here
Kouts, In
No visual aid. But your tensioner is under your alternator.
---------- Post added at 02:01 PM ---------- Previous post was at 02:01 PM ----------
I hate to type it, but I think your engine gave up the ghost.
texaschevyryder
texaschevyryder
LAWTON,OKLAHOMA
ok i will take pics and confirm by finger pointing
---------- Post added at 02:13 PM ---------- Previous post was at 02:11 PM ----------
well let us hope that it has not if so im not buying another car gonna give my hoe a new engine
jmildoc
Indianapolis,Area
i think your motor may be done too...... hope not but it may be....... If so deffff do the 383 swap... I know you can find some good deals down in texas.... where are you from there?
Sepiroth..... did you see my intake... I think I got it from the same people as you it came in the same box as yours......... Check out my pics..... That filter is HUGE!!! Huh
Sepiroth
I am here
Kouts, In
Hi-jack
I cant find your thread on it. lol. Yea the filter is huge! How are you enjoying it?
Did you too find the instructions a bit less than desired?
I havent had a chance to fill up. I'm at half tank so maybe tomorrow, I top off again and check MPG's.
Buford bubba
