Tahoe 2024 GM Exhaust Upgrade
Boston
Studying pictures online it appears the GM performance exhaust by Borla has a resonator before the muffler and no spring-loaded valve, while the GMPP Performance Exhaust (84888291) doesn't have the pre-muffler resonater but has the valve. I'm referring to the spring-loaded valve that's intended to help with DFM drone, we've established these trucks never got an active exhaust valve. This was just observed from looking at pictures, I've never set eyes on either in person.
I was leaning towards the GMPP version because GM actually qoutes an 11hp increase but they don't say the same for the GM by Borla version. Also, I'm assuming the RST Performance Edition uses the GMPP version from stock, and that truck is officially listed at 433hp, with GM stating most of that is via the exhaust upgrade. Makes sense, most people acknowledge that a CAI provides limited to no actual power bump, especially without a subsequent tune, and the RST Perf Edition only gets exhaust and CAI for its power bump as far as I know. I feel more confident the GMPP actually provides a bump in power, being that OEM car manufacturers tend to be conservative about officially listed power numbers. If that ~11hp bump is even noticeable in actual real world use is a whole other conversation.
I'm really torn, the GMPP is around $3,300 whereas a catback directly from Corsa or Borla is quite a bit less expensive. Also, the aftermarket cat backs don't have the valve, and I really want to avoid DFM drone, I read that it sounds like a helicopter when cruising and DFM activates. Guess I could play around with that mod people do to hold the stock valve open to see what it sounds like, that only costs a couple of hose clamps and a few minutes under the truck.
Someone help steer me right on this, I want catback exhaust, I would rather err on the side of a mild volume increase as opposed to being obnoxiously loud, and I absolutely want to avoid drone, which is a hard line for me - zero drone required. This truck is mainly driven by me, but I do take my family on road trips. I also would feel more justified spending the money for a HP gain, even if it's modest, and even if it's not necessarily percentable I would feel like it was more justifiable. If I just wanted more sound, I could have a muffler shop switch out the muffler alone for just a few hundred dollars compared to several thousand for a catback.
..how about the “active exhaust” they offer on the pickups?
SavageDad
I might replace the stock muffler with a Flowmaster super 10. Keep everything else except the spring flapper valve. Question is, I was looking underneath and just ahead of the third cat converter there is a chunk of metal, 4”x6” 3/4 thick, welded to the side of the pipe. All by itself. Anybody know what this is, for?
Did you end up going this route? I want something slightly more aggressive for my 5.3 Z71, but I still have drone ptsd from when I swapped the center suitcase with Super 10s and axed the resonators on my old Magnum SRT8. It sounded great at idle and WOT, but cruising sounded like an old Crown school bus.
Tinman265
I did the GM Borla. I also have a Range AFM defeat installed. Little aggressive on cold starts but sounds good on the road. definitely noticeable when you get on in.
z-denali
Hi folks - recently got a Tahoe RST 2024 with the Sports Performance Package, so already have the dual-exit exhaust.
I've been looking for a slightly gruntier sound but mostly when WOT. We do go on road trips often so I don't want something too loud while cruising.
Chevrolet have 2 different exhaust upgrades:
1/ 6.2L Cat-Back Dual-Rear Exit Through-the-Bumper Exhaust Upgrade System with Quad Chrome Tips (for Short Wheelbase Models) by Borla®. Part number: 19433760.
2/ 6.2L Cat-Back Dual-Exit Exhaust Upgrade System. Part number: 84888291
I've seen a lot of different statements around on whether:
1/ The 2nd one is also made from Borla
2/ Whether the 1st one is a Touring, S-Type or somewhere in between
3/ How loud is the 2nd from stock and if it's worth the upgrade
Would love some first-hand insights from anyone who have any of these or tried both! Thanks!
I have a 24 Tahoe HC 6.2 with the GM (Borla) upgraded exhaust, dealer installed. Loud when you hit it, but super nice (quiet) cruising
BacDoc
Vero Beach Florida
Is this the GMPP 84888291? This is supposed to add HP/Torque
The other option is less expensive and just described as the Borla upgrade exhaust. Part number is different.
Capybarbro
