P2671 Actuator Supply Voltage B Circuit High
redncrash
Hello,
My 2005 GMC Yukon XL 1500 Autoride 4x4 5.3, is intermittently pulling OBD2 scanner code p2671. It pulls this code twice. The only symptom is right before code illuminates, when driving between 40-50 mph is the transmission jumping between 3 and 4 gear. This SUV runs great! Transmission shifts smoothly at all other speeds. I have researched for several days with only very confusing information. Can anyone help?
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in this area will chime in.
@NickTransmissions is our resident transmission expert, and he may be able to provide some troubleshooting tips.
redncrash
redncrash
Thank you, I pray someone can help with this code. I did put a photo of my truck up.
redncrash
redncrash
You have a broken wire between your TCM and solenoid(s) within your transmission. The broken wire can either be internal to the tranny OR on the chassis mounted wiring harness.
Thank you for the information @rockola1971 . We will be checking for a broken wire this weekend.
TexasTaz
