DFM disabler released
djnice
I am not sure "coast longer" tells us dfm is on or off. Benefit of the range is that you can still use another obd device to monitor cylinder activation or other stuff.
What is really happening in 0 cylinder mode? All valves stay closed?
@rangetechnology8178
1 month ago
Hey, thanks for your review on our device. We're sorry you weren't pleased with the results. We went through ALOT of testing and disabling the 0-cylinder mode at 0% throttle input had some negative driving results we weren't happy with. Disabling that 0-cylinder mode removes the vehicles built in engine braking and caused a massive dropped in fuel economy (2-3mpg) so we opted to leave the 0-cylinder on decel active. After feedback from some users, such as yourself, we are working on implementing the ability to choose whether you keep 0-cylinder or not. We'll be sure to keep our social media channels updated on that progress.
Show less
Scarey
Really appreciate your feedback, but I’m not following you with this part. If your RPMs increase going down hills, doesn’t that mean that the transmission is downshifting and the engine is providing braking? (If so, you’d want that when towing a load, no?) Hoping you can clarify this for me. Thanks.
Don’t know, just be careful going down hill while using carbyte.
KMeloney
I’m not questioning anything you’ve experienced. I’m just trying to understand what you’re saying.
Are you saying that with the Carbyte in, you DON’T get the same engine-braking/slowing of the truck going downhill as with the Carbyte removed? Or the complete opposite?
Thanks again.
Scarey
Stock configuration, stock deceleration when you take your foot off the gas.
Range 007 configuration, stock deceleration when you take your foot off gas.
Carbyte configuration, doesn’t slow as quick when you take your foot off gas.
djnice
I like that the Carbyte can also be used for scan and monitoring. And you can turn on and off the autostop. Not slowing as quick with foot off gas doesn't seem better to me. I don't feel like this vehicle engine brakes more than a non-DFM.
Scarey
Yes coast longer is a by product of Dfm being defeated.
fondupot
South Carolina
Hows everyone's experience with this unit been? I have one that I just need to get around to installing it. Maybe this weekend.
Antonm
The Range unit works fine, just disappointed to know that its not actually a DFM disabler, its more of a DFM condition modifier it would seem because DFM still happens on decel.
Scarey
Their web site still advertises “all cylinders all of the time”. There is a note which explains the decel, coast, 0 cylinder mode, not really “all cylinders all of the time. Unfortunately I bought their product thinking it was “all cylinders all of the time”. I don’t think that note was on their web site when I purchased it. Does that qualify for a refund?
fondupot
South Carolina
I just installed mine today. I'm happy with it. I didn't notice the 0-cylinder on decel tho (before or after the unit). I am just happy to have AutoStop turned off, and AFM/DFM turned off when cruising in Drive. Before I could feel AFM/DFM kick in and there was a flutter/vibration accompanied. Now that is gone.
jfoj
Just so everyone is aware, and Range did not have this info on their website in the description, when the Range 007 device is plugged in the Evap and O2 Sensor Emission Readiness Monitors will not become Ready. So if you live in an area that requires Emission Testing, you will need to remove the Range module for the Emission Readiness Monitors to fully become Ready prior to Emission Inspection, otherwise you will not pass an Emission Test. This is based on OBDII Emission Inspections.
I emailed Range and they confirmed this is the case, but again, nothing on their Website about the Readilness Monitors. Unclear if this will impact OBDII codes from triggering in the future, unclear if OnStar monitoring will pick this up. Based on the price point, this is clearly some form of Spoof module rather than a sophisticated microprocessor that alters the data stream the inhibit AFM.
So BEWARE, you WILL NEED TO REMOVE the Range device prior to Emission Testing.
Overall I am fairly happy with the performance of the module, but so far I only have about 300 miles using it.
KMeloney
I always suspected this was the case (and knew I had to remove the Range unit I used in my '09 Tahoe prior to emissions), but thanks for confirming. This has me leaning harder toward the Carbyte unit.
If the Carbyte unit kicked in immediately -- not only after reaching 40 mph -- it'd be an absolute-no brainer for me.
jfoj
While the Range 007 is not as easy to plug in and out as and OBDII adapter, it is still not very hard to install and remote. On my 2024 Yukon with 22" wheels, I did not need to remove the drivers side wheel, just like 6 small screws for the inner fender liner and pull it out of the way. If you have the proper tools in hand, under 10 minutes would be about the time it would take to remove/install.
Antonm
I was all jazzed when Range Technology , a division of Holley, one of the biggest names in the automotive aftermarket, finally came out with this device. I ordered one up basically a week after they came out (and they were already on backorder at the time).
But between them leaving on the 0 cylinder part of DFM on/ functioning (making the device a DFM schedule modifier and NOT a DFM disabler) and now the O2 sensor not ready flaw, I'm way disappointed with it.
I emailed them just prior to Thanksgiving requesting a return/ refund because the device isn't a DFM disabler. They did respond to the email saying I should hear something from Holley in a few days, so we'll see if that happens (haven't heard anything yet, but Thanksgiving may have delayed their response. Below is a screenshot of their most recent return email.
Kpwweb
Obviously this is up to you. On a Z71 I do not have the problem of 0 DFM—all cylinders are still active and do slow me down on hills, much like if the truck were a manual and I used the engine and transmission to slow me down. Even happens on the highway downhill. Most of the time the truck will maintain the same speed instead of accelerating. Further, I can feel the transmission downshift and the engine hold me back when braking for a light.
I am very pleased with the Range and even the thought of potentially avoiding lifter failue in the future (already had one failed set) makes me giddy.
To each their own.
Antonm
To each their own.
Why do you think the Range device will "potentially avoid lifter failure" when it still has the DFM functioning during the 0-Cylinder mode (which is literally every time you drive the vehicle and come to a stop)??? Having the 0-Cyilder part of DFM still enabled totally negates any potential lifter saving or reduced failure it might have.
Basically the one and only thing its good for is making consistent exhaust sounds for those with modified exhaust systems. Which I guess if that's something you care about then sure, the range tech device works fine.
KMeloney
There's no improvement in acceleration and transmission smoothness with the Range? Geez. Sounds like a complete waste then.
Antonm
No, not in an otherwise stock vehicle there isn't anyway. Our 6.2 High Country Tahoe didn't have any acceleration or transmission smoothness issues before the Range Tech device.
Before the Range Tech device, if you turned the radio off, and told the kids to be quite, you might, maybe, be able to tell when it deactivated cylinders if you tried real hard, and even then it was a maybe. I'm sure with an aftermarket exhaust it would be much more noticeable, but the stock exhaust is pretty dang quite.
And I agree with your last statement, it is a complete waste IMHO, unless you have a louder aftermarket exhaust, and the sound of the cylinder deactivation bothers you.
If Range Tech would make an actual DFM disabler (you know, something that just turns the dang DFM off, like how hard its that, just turn it off), then I would be first in line to get one.
jfoj
I would say there is an improvement in acceleration and transmission smoothness, or at least not having the engine hunting and turning cyclinders back on during tip in throttle and acceleration. This then equates to less or no transmission hunting as well.
I am still not sure about the "0" cylinder on deceleration, I can say it appears that there is Fuel Cut Off on deceleration, this has been used for years on GM and other manufacturers. My 2006 6.0 Yukon Denali has Fuel Cut Off on deceleration. I would watch the engine temperature drop quite a bit on my Ultra Gauge while engine braking down the PA mountains in the Winter. When you pump cold air thru the engine with no fire in the holes, the engine temp would drop 30-40 degrees depending on hold long the downhill grade was.
a1parrothead
