2023 Yukon AT4 Lift Kits
Patrity
Hey all!
I recently picked up a 2023 Yukon AT4. I'm pretty eager to take it up from stock height. In my other trucks, I typically stick with BDS kits due to their build quality and the quality of fox shocks.
It looks like BDS doesn't offer a kit for these Yukons. What is the "go-to" kit for people lifting these trucks? I've always known to stay away from rough country, even though the price is appealing, the ride quality has been known to be pretty rough.
I'm not decided on 3" or 6" yet, but just looking for good options.
Thanks!
jgraves
Icon makes a 3" lift and has a generally good reputation.
FWIW, you can fit 315/70R17 (about the same dimensions as a small 35x12.50) at stock height by pulling back the fender liner and careful wheel selection. Mine are Hakka LT3 for winter and they measure almost identical to the BFG KO2 35x12.50, which I'll likely go to for summer once the factory Goodyears are finished.
If tire fitment factors into the height lift you choose, my objective would be any 35" tire and near 0 offset with a 3" lift and a 37" tire if lifting 6". I don't know anything about tire fitment with a 6" lift or if 37's would require a re-gear but personally, if I couldn't fit 37's, I wouldn't consider a 6" lift.
With the 6.2L and factory gearing, the difference from stock to 315s is barely noticeable. I haven't towed with the 315s not do I live in the mountains.
Jeff
ProfeZZor X
High Country
I chose the 3 inch Ready Lift kit. I wanted parking structure clearance, so that's the route I chose. With my 24's on 35's, I top out at 6'6"... And yes, I easily clear parking garages.
SavageDad
Jeff
What did you go with for your 17s?
Big Jim
