opfor2
So, what actually is a Z71Tahoe vs. a normal Tahoe?
from what I understand it is basically just a different mostly trim package, 4wd, running boards, shocks, skid plate (however) the skid plate could vary from plastic to aluminum depending.....So, what actually is a Z71Tahoe vs. a normal Tahoe?
I've wondered the same. Is my 4WD in any way different from other 4WD?So, what actually is a Z71 Tahoe, vs a normal Tahoe?
So far, this has been impossible for my 22 year old Tahoe.You may try looking up the GM Tahoe brochure online for your year and it does list information about your particular model.
the "basic" difference with the ssv/ppv versus stock is the suspension is 1" lower, there are ssv/ppv specific suspension partsI've wondered the same. Is my 4WD in any way different from other 4WD?
Is the Z71 suspension different from a non-Z71 4WD Tahoe? If so, how so?
And questions like that ... specifically:
What are the pertinent similarities between a SSV and a Z71? Differences?
What are the pertinent similarities between a PPV and a Z71? Differences?
My fear is that I will never get helpful answers to the last two questions.
I want to create a Frankenstein using my very loose definition of GM OE ...
well since the ppv are 2wd and ssv are 4wd I guess that would explain why 1 is 1" lower and 1 is notNot concerned with the tune, me & my tuner already have that covered. Won't drive my Z71 over 90MpH anyway -
plus I'm far more interested in fleshing out how to make the engine and transmission suddenly reluctant once coolant hits 221F.
My major concern is springs (torsion, coil), shocks, swaybars, and that panhard bar.
The SSV is not 1" lower, yeah? Only the PPV is lower.
Are the SSV and the Z71 the same height, or is one taller than the other? How is this accomplished / spec'd?
I have 2 Z71 Tahoes, both 4wd models. I know a guy who, surprisingly to me, has a 2WD Z-71 Tahoe that he bought new. I had thought that all Z-71s were 4WD.from what I understand it is basically just a different mostly trim package, 4wd, running boards, shocks, skid plate (however) the skid plate could vary from plastic to aluminum depending.....
there are always different options depending on how it was ordered, tow package, trailer package, heated or heated & cooled, or not heated seats, adjustable or not adjustable pedals etc
power seats, hud or no hud yada yada
my silverado is a z71 but it is also a lt2 and texas package+ dealer add-ons
ya I did as well until somewhat recently, it's like assuming a denali has a sunroof not all of them do........ but everyone of them you see does lolI have 2 Z71 Tahoes, both 4wd models. I know a guy who, surprisingly to me, has a 2WD Z-71 Tahoe that he bought new. I had thought that all Z-71s were 4WD.
There was a year when GM decided that RPO Z71 could make them more money, if they let 2WD models also use it.I have 2 Z71 Tahoes, both 4wd models. I know a guy who, surprisingly to me, has a 2WD Z71 Tahoe that he bought new. I had thought that all Z71s were 4WD.
This should be pretty typical for the 2015-20 range.You may try looking up the GM Tahoe brochure online for your year and it does list information about your particular model.
This. FYI, the z71 suspension has slightly taller/stiffer springs than the regular LT 4wd.This should be pretty typical for the 2015-20 range.
: Z71 Off-Road Suspension, 3.42 rear axle
ratio, Autotrac 2-speed active transfer case, high-capacity air
cleaner, Hill Descent Control, Front and Rear Park Assist, Black
recovery hooks, foglamps, and Z71-specific features including
unique grille design, skid plates, 18" wheels with off-road tires,
Black tubular assist steps, front sill plates, rubber floor mats
with Z71 logo, Z71 decal on instrument cluster, and Z71 badges
on pillar and liftgate
you would think, but...... actually almost all of them are 3.08, and rare to have front park assist, skid plates vary from plastic with a metal support to full aluminum.This should be pretty typical for the 2015-20 range.
some of it depends on the trim level besides just z71
I should add that's based off pics online and looking for the sensors. Oddly a lot of sellers don't seem to make as big of a deal about listing them as Z71s compared to that option on trucks and older Tahoes?Most seem to have the park assist but in any case that's the Z71 features list from the brochures. They claim it's only available on LT.
