24 Tahoe 6.2L - Flashing Engine Light
FrankG158
I was driving my Tahoe today and the engine light started flashing. I live in the mountains so it was our normal climb home to about 2k ft. Ambient temp was 110. The light stopped flashing almost immediately. This happened once before on another very hot day except that time it included traction control and another light. What is going on and is it serious? 4200 miles.
flashing check engine light generally indicates a misfire is happening, so ya take it to the dealer, could be something simple
btw it can go to ANY gm dealer nation wide, doesn't have to go to the purchasing dealer
Steveo123
My 22 6.2 been doing this for awhile. Light flashes for maybe 30 seconds at most then goes away. I’ll pull out my cheap scanner and it always comes back as a misfire on cylinder 3. I actually just picked my Tahoe up from the dealer today for an oil leak and had them check for the misfire codes also. They can’t or won’t do anything unless they get the light to set while in their possession. But they do see the misfires in the history. My warranty is up in a few months and I really don’t know what to do.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Hopefully the info you just shared about codes and history is documented on paperwork the dealer gave you. If not, GET IT! Then ask to speak to the service manager and then the district manager and then......
sounds like bs but.... optionally you can ask and PAY out of pocket for a diagnostic, usually it should take them no more than 1 to 2 hours to find the cause of the misfire.
that get's you somewhere anyway, then the warranty portion would kick in and then you can go to the owner/head manager and plead your case for the diagnostic fee.
Sean Michael
DFW
Did you ever look further into your check engine light flashing? My 2024 6.2 Tahoe also flashed the check engine light today.
WalleyeMikeIII
Sunny and Snowy Minnesota
Your powertrain warranty is 5 years, 60k miles, so if it is engine internals, you are covered...for a bit more.
It is useful to take a video of the issue happening that also includes the mileage...you can use this to your advantage (aside from the danger of running your ride while using phone), have someone else take the video.
Steveo123
Yes, had video of the light flashing and video of checking the codes with my scanner. They don’t care.
They kept it for almost a month and they only fixed the oil pan gasket leak and did not address any other concerns. Misfire, rattling exhaust and a clicking cv axle they told me could not replicate.
After only putting 100 miles and a week of having it back got a message on the dash “ Service transmission now unable to shift soon “ so had GM roadside tow it back to them last week and they still never looked at it. Don’t know if they did something to it in the time they had it or just coincidence.
WalleyeMikeIII
Time for a conversation with the service manager and the dealer general manager. And if that doesn’t work, a convo w GM and a new dealer.
davesproblem
